weird top
that jeep looks like it needs to have its roll bar surgically removed
According to the listing that's an '87 CJ7. That top must have been unique to that year:rotfl::rotfl
that was on another forum a while ago... it is a scrambler hard top modified to fit a 80-86 rollbar for a CJ7... 87 CJ7 huh? that is pretty rare :crazy:... someone snap it up!
That looks like a Matt Donaghy original!
Probably worth MILLIONS! :eek:
very strange indeed
It does not appear to be an OEM one that was modified. Probably only myself and a couple of other people on here would pick out the details of this to tip this off..
a. if you look at the lip around the door, on the factory OEM top, that lip is a complete upturn. this top its simply a "ridge" one of the detail shots of the door openings can determine this right where the paddle handle would be
b. if you look on the inside picture, you can barely see the back interior surface and you can see the non smooth surface to see a fiberglass texture. OEM factory top had an inner liner that was smooth/finished
c. the rear window opening size is non standard size - if it was larger, it might have been cut to a larger opening, but if its smaller, someone would have had to go to a lot of trouble to fill it back in. highly unlikely
d. the rollbar cutouts.. you can see just a small part of them on the inside view. hard to explain, but with those type of indentations, and the lip on the door surrounds, it would have had to be a 2 or 3 piece mold to accomplish those little indentations. Was unlike a factory OEM mold probably because the inner liner was mated to the outer shell of the hardtop at the door drip rail flange...
more than you ever wanted to know about CJ8 hardtops I suppose.. but thats my guess on it.. my guess it was an actual limited production by an afternmarket or some other non OEM company.
just my .02
