welder advice
one thing i like is a welder with a variable voltage knob...alot of the cheaper welders just have different taps on the transformer to plug into...u can do a better job on different thicknesses if u have more voltage control...though not necessary....
the other day on tv land i saw mcgyver weld an engine block with a car battery and a nickle...:rolleyes: :D
Millermatic DVI. Dual voltage 120/240, single phase. Best of both worlds. Power is between the 175 and the 210. Will do 3/8" in a single pass. Cost around $1300. Then you'll want the shielding tank(s).
Got one for "The Boy" for a HS grad present. Now he builds aluminum fire trucks for a living. How 'bout that: a present that paid off big time.
I've taught quite a few people to weld with a stick. As long as they'll listen most can pick it up pretty quick.
Yes you can get 70ksi wire, and I thought most people used that anyway. But the weakness comes from impurities due to no flux. Flux is a cleaner and a shield. Gas just shields. Another thing with mig is that most people use too small of wire when welding thicker stuff. Their little wire works and they can make a big pretty weld with it, but it doesn't put enough power through the base metal.
And then there's times you can't fit the mig gun where you need to weld. But a stick might reach it, or can be bent to go around things.
I've never heard of rewireing 3 phase equipment to work on single phase power, besides having a motor rewound from 3 phase to 1 phase. And you can rewire most things from 440 volt 3 phase to 220 volt 3 phase. Then get a phase converter to turn your 220 volt single phase into 220 volt 3 phase. But the phase converter costs $500+ depending on how big of one you need. Its still a good option to run that $300 mill you bought at an auction.
my mistake
I think when I said I told you all I knew I actually told you more then I knew. Ryankopecki was right about the three phase/single phase. I was thinking the 208 voltage was three phase.
:o Leave it to someone from Texas A&M to spot a fool.
Ryan,
Can you weld sheet metal (body parts) with a stick welder? Here's what I'm going to be doing:
1. Taking out a small (6") section of rusted frame and welding in a new piece.
2. Welding on the MORE frame plates for extra support.
3. Welding in new body parts and pieces to fix body corrosion.
4. Possibly welding other parts such as roll bars, suspension mounts, etc.
5. Finding things to play with after the rebuild to justify keeping the welder around.
I figured the MIG would be able to do it all, as long as it's strong enough for the frame and MORE plate thicknesses.
:confused:
Canzo, a mig is just about right for the thickness of steel on jeep. You will normally not find something on a jeep that is larger than a 1/4 in. Before all you other guys chime in, I said normally. I know there are plenty of occasions and you master fabricators that use bigger stuff, but for what I think Canzo is going to use this for a 175/180 mig will work well for him.
Truck
Hey Canzo.
Shoot me an e-mail sometime and we can get together. I have a buch of welding stuff over here that you can try out.
From my personal experience if you can spend the dolars get the Millermatic 210 or better yet the DVI. The DVI is almost the same as the 210 but with a little shorter duty cycle. But you can use 110v whenever you need to. Also you can get a Spool gun to weld aluminum with.
If you need to go for less money then the Lincoln SP175+. Get the plus as it has infinite voltage instead of tapped, or steps. It is much nicer for tuning. Actually the 175 range is good for a lot of stuff and will let you do some heavier stuff. If you are doing axel work then tack and takle to a professional.
BTW, if you want to try Stick or TIG I have those machines too.
Carl
Yes I can weld body panels with a 1/16" rod. It is not easy. And takes a long time. There are nearly 20' of stick welds on my jeep's body. That was before I had a mig.
Thanks guys. I really appreciate the help.
Carl,
I will try to take you up on your offer sometime soon. Are you coming to the dinner on the 15th (see JOKER's return Event thread)??? PM sent.
TIG is the only way to go!!!!
sorry guys I don't trust MIG, I have fixed factory weld after factory weld on my bobcat, they use those MIG welds, we have used 6010 low-high or TIG over and repaired many places that have ripped apart, the next time it ripped through the 1/4" plate instead of the places we have welded tig is hard to beat it just takes alot more patience, but hey we're talking jeeps, here, they aren't taking as much beating!!:) anyway I just have gotten in the habit of Tigging everything!!
just my thoughts if they are worth anything!!
