I've taught quite a few people to weld with a stick. As long as they'll listen most can pick it up pretty quick.
Yes you can get 70ksi wire, and I thought most people used that anyway. But the weakness comes from impurities due to no flux. Flux is a cleaner and a shield. Gas just shields. Another thing with mig is that most people use too small of wire when welding thicker stuff. Their little wire works and they can make a big pretty weld with it, but it doesn't put enough power through the base metal.
And then there's times you can't fit the mig gun where you need to weld. But a stick might reach it, or can be bent to go around things.
I've never heard of rewireing 3 phase equipment to work on single phase power, besides having a motor rewound from 3 phase to 1 phase. And you can rewire most things from 440 volt 3 phase to 220 volt 3 phase. Then get a phase converter to turn your 220 volt single phase into 220 volt 3 phase. But the phase converter costs $500+ depending on how big of one you need. Its still a good option to run that $300 mill you bought at an auction.
