- Hernando
- FL
thanksMy stock '83 is 43-1/4" from center to center of bolt holes in each mount
So angle / slope to the rear?Id would switch the rear hangers around. Angle so spring hanger wont get hung up on obstacles.![]()
Yes there is a very good chance they're on backwards. I had a fifty percent chance of getting it right (one more reason I don't play around with Vegas). Currently they are just placed on frame will rotate them as you folks recommended. Then probably tack weld, turn frame over and install drive train. Question with a fully built jeep (I mean completely assembled) what approx. angle should the front hangers be at?Trevor (owner at WFO) is a friend... and a really great business person.
It also looks like you have them on the frame backwards.
ThanksThe more angle, the softer the ride.
I like about 10-15 degrees
I see dogleg thanks. The springs look almost flat as she sits. Is that fairly normal or.... spring over?Remember YJ springs are 1" longer.
I use dogleg shackles to eat up some of that, but you can also see the angle on mine, which is spring over on a Chevy 60 front.
Also your rear mounts appear to be in the stock position so I can see the reason for the dogleg shackles. In my case the rear mount can be welded to compensate for extra length YJ springs. Great info thanks.Remember YJ springs are 1" longer.
ThanksLooks good!
