What can I steal from my wife's 92 Trooper?
johnnyvol
Iron City
tn
My wife's beloved 92 Trooper may be on the way out. Its becoming unreliable and we may be replacing it soon. What, if anything can I steal from it for use in/on a Scrambler? I'm either going to rebuild mine or get another to do a ground up, but I'm not stuck with keeping everything original. Is there anything on this model Trooper that would be good for a swap? Or should I build it up into a wheeler?
Thanks for any input.
John
The rear axle is beefier than a D44, has a higher pinion entry level, disc brakes, and probably 4.56 gears....
I have a '93 Trooper and I've wondered the same thing. Mine has 304,000 miles and still runs pretty good. I don't hesitate to drive it anywhere. Very few repairs through the years. But the oil pressure is low and I know one day the engine will go or just get too weak.
I don't know what axles/gears it has but I was wondering if they could be swapped into one of the Jeeps if I ever need to. It's a 5 speed. The transmission seems pretty stong.
I thought that it was the Rodeo not hte Trooper that has the Dana 44 that will swap into a CJ.
Carl
Correct- the Rodeo has a D44 with disc brakes and usually 4.27 gears, using a thick gearset and a 3.73/down carrier. Funky driveline flange, but can be swapped for a std D44 flange.
The Trooper has a Corp rear axle- it looks like a ford 9" or a toyota rear end. It has a drop out carrier. They usually came with 4.56 gears, disc brakes, and occasionally a factory limited slip. Lockers are limited to ARB's and Aussie Lockers. The advantage is the bearings/axle shafts are larger, and it seems like the pinion enters the carrier at a higher point. The axle shafts are 26 spline, however. I have a Corp rear end and am going to try it in my Scrambler. We'll see how it holds up to a 300HP/350FTLB Small Block Chevy and 36" tires...:evil:
I think JP had an article on top axle swaps that listed the Trooper rear for all the reasons that Randy mentioned. I believe you also need metric adapters for the brakes in addition to swapping out the flange for a yoke IIRC.
Yep...forgot about the brake line adapters.
