What did you do with your Scrambler today? April 2014 version
What show is that Karl ?
Just a local car show that a school has every year. It is put on by the kids from the school. Its been going on for over 10 years and is fun for my kids. All makes and models, not a Jeep show.
Karl
Successfully trimmed up the rocker knocker and installed it along with the other HEI I had from an older motor... removed the old 401 dizzy as I wanted to run the DUI HEI... everything fit well.
I had the garage door open as well, thus the weir reflection on the back of the Jeep with my crappy 1980's cell phone camera. It was actually somewhat warm out... I was very confused.
It straightened out a few hours later when the temp dropped and was down in the 20's, so things were back to normal ;)
So I got the lift kit installed over the weekend.
Then today she got new shoes and laces (lug nuts with lock).
Went with 31x10.50 on 15x8's. Spray painted wheels. This weekend is helicoil the valve cover, install the new to us fold & go rear seat (in garnet red) and then drive the snot out of it.
FYI - different wheels were spray painted. I still have the white spoke 15 x 7's.
IMG-20140410-01359.jpgGave the jeep a rinse in the creek after winching it out of the neighbor's place, and went for a drive to make sure it still went highway speed. Moab coming!... :) Still have to pull that transfer case and a few other things need doing.
Didnt do anything but i did buy a fold and tumble back seat out of a 2012 JK Wrangler 2 door to modify to put in the back of the Scrambler.
I will put it in my build thread when i get around to doing it. (Probably summer time)
I got the GM hydroboost and Corvette master cylinder installed! Took it for a test drive,WOW what a difference!!
Tomorrow's plan is to get the air cleaner to fit on the newly installed Howell TBI.
I love my hydroboost brakes.
Bike lessons
Just taking the 5yo to the school parking lot for 2-wheeler lessons. Also lots of lacrosse practices, a I coach my 8yo - nice to be able to put the gear and mini-goals right in the bed (no pics).
Today was new shoulder harness seat belts and fold & go installed with seat belts. Tomorrow is helicoil time and then drive.
Went for a long test drive today. Discovered I need to rebalance tires for the interstate, heard a vacuum leak whistle sometimes, found a loose tie rod end and need to replace that darn gasket at the top of the windshield. Also got several compliments! :woohoo:
Is the gasket for the windshield readily available? I need one for next winter when I put the hard top back on.
Dain
Dain
I didn't have any trouble finding one. I did use a piece of soft cord taped to the frame for a while - the old gasket is there, just flatter than a cinch bug.
Haven't worked on the Scrambler in a while. Been working on the J10 and today I installed an OEM receiver hitch on the XJ (what a PITA that job was!).
Also painted the rear plastic bumper ends with some Krylon Fusion satin paint. Makes them look brand new but also makes the side molding look even worse! Looks like I'll have to paint those soon!
Valve cover sealed tight and put some miles on her today.:woohoo: Got lots of looks, thumbs up and smiles. I noticed I am almost to 10,000 miles so I told my wife I will have to run up to the local dealership and ask for the 10,000 mile service.... I would love to see the look on their faces. :D
Put a D-shaped gasket in with the original windshield gasket - that seems to be tight. Had to squish the top down on it with a jack. I can always try the replacement one if this doesnt work. Also tried some Wiperboy wiper arms. Not sure if it looks right, but it got too dark for pics.
Did you/will you do a technical writeup on this? Part numbers, donor vehicle info, procedure, observations, etc...
Going to be doing hydro brake conversion on my Scrambler soon myself and could use any kind of detailed information possible.
Thanks:wave:
I removed the heater box assembly today to replace a leaky heater core and upgrade to the YJ blower motor. :woot:
