What did you do with your Scrambler today? April 2014 version
My son helped me install a Skyjacker 2.5" soft ride lift. PB Blaster was a key item in the work. Only ran into 1 issue. The passenger rear spring perch was bent up really good. I had to cut off a good portion of the shock mount to get the Scrambler back together. No worries, I will swing by Collins Brothers and pick up a new one on Monday. 1st time doing a lift, and it went great.
Installed my new to me soft top. But I have a couple of questions. One is, is there a learning curve to taking it down and back up without taking a ton of time?
Also, the zipper for the seat belt bolts has plenty of room that I do not need to cut a hole, but I can't see how to zip the zipper down after screwing the seat belt bolt to the roll bar. Is it possible or do I need to leave those zippers unzipped?
And with the soft doors on.
Dain
Installed the ARB mini-compressor this weekend.
Dropped it off at Mr. Beep's axle guy last night for rear Scout 44, 4.10 R&Ps, ARB in back TrueTrac up front.
NO PICS! If you want to see it, you have to come to MOAB next month!!
Got a used passenger rear spring plate from Collins Bros today. A little wire wheel cleaning and paint and install. All done while my wife took the girls to volley ball practice. And I even made dinner before they got home. A pretty successful evening. And for anyone that was watching the garnet red fold & tumble rear seat on EBay - sorry - it should show up tomorrow and will get it installed this weekend.
Busted junk? Busted Junk? BUSTED JUNK? It was temporarily decommissioned :D:D. Nothing was BUSTED.
I drove mine about 30 minutes to buy another one.
That was after going shooting.
drove uncle Bugs scrambler to work today, testing out the swapped 4.0L w/ 42re auto. Newer JK parked next to me at gym.
Excellent. Nice to see the young ones respecting their elders.
Haha he has a little write up on a separate tread..
Sent from my SPH-L900
ya, JUST found it. Catching up here after being at work and not having time to come on here for a few days.
played around with how much to cut off the rocker knockers to allow for the new fenders as the wheel openeing is much further back.
added heat reflective sleeve to my fuel feed and return lines where they come close to my exhaust. Haven't had any problems, just want some extra heat protection since it hasnt been in the desert since the motor swap. Didnt take any pics.
Started to set up the cruise control system. Something is wrong. I messed up the wiring somewhere. Either a bad ground or a wire for the brake lights. My back said I'm not in any condition to do wiring, so it will have to wait. Hope I can get it fixed before we leave for Moab, especially considering I installed cruise for this trip!!!
I also changed out the stock grey (not faded, same color as hard top) fenders on the 05 LJ to a set of new black ones from Rugged Ridge. When I was almost done, I went to put the extension flare onto the passenger side, the color was WAAAAAAY off. I called Summit (where I ordered the kit from) and they are sending me a replacement. "throw out the mismatched one, no need to send it back"
Just a "slight" difference. At least I am able to get a replacement, hope its black and not this color!
Looks so much better in black... Now I have to do something about the bumper..... and fog lights... and the grey hard top... and... and.. and...
Then I temporarily covered up the rust patch on the passenger rocker. They didnt properly apply the seam sealer from the factory so the seam rusts from the inside out and splits. I am buying a TJ tub for $100 and I will cut out this part and replace it, eventually... You can see the rust patch in the other pictures. The tape took off the dirt...
Put the Laredo emblem on my glove box and cleaned the chrome rims. Getting ready for a show on Sunday.
Karl
