It reminds me of the clamp that hooks to the end of the stabilizer shock up front that clamps to the tie rod that goes from the pitman arm to the steering knuckle?
All good ideas, I'm going to crawl around it today to see if anything lines up with it. I thought maybe it was one of the pieces for the steering stabilizer but nothing in the stack of pictures I took during the teardown look like it. I also thought it might be the under hood light bracket but the holes just barely don't line up. The fact that it's not immediately recognizable makes me think it's something the PO added to hold or prop something up. He did have a piece of angle iron serving as the trans crossmember after all.
The holes look wallowed out... like it was a back bracket for something... like on the other side of the tire carrier to support the bed from collapsing... like they didn't have the original one so they made this. I don't recognize it though from anything I have taken apart... the bottom edge looks like it was welded to something and then it was cut off or bend back and forth till it broke off
