What to do?
I’m getting the axles from ECGS….. I’m going with the Detroit TrueTrac on the front…what‘s your opinions on the rear…Detroit Locker or Detroit TrueTrac? Lemme know what you all think.
Going to be more of a road scrambler vs trail.
Thanks!
If bias is towards more road use, go with the TrueTrack rear. The Detroit Locker has some quirks on road.
I have OX lockers front and rear. I set mine up with good street manners in mind. It is an ice cream runner much more so than a rock bouncer. Before this setup I ran a lunchbox in front. If I were you, I would be tempted to run a full Detroit in the front and twin stick your Dana 300. If not going selectable, I would for sure recommend the True Track over the Detroit in the rear.
Another question….The ECGS d44 front axle setup is lo pinion. Is that what I want when doing the OME springs?
I wouldn't think pinion placement is affected by SOA vs SUA. I am guessing they use the low pinion casting as the perch is ready for SUA. I would be tempted to see if they offer a high pinion front. A high pinion front is like 30% stronger than a low pinion.
You'll need the adapter kit for your frame but the axles will work perfectly.
What is the adapter kit? I got the Rocky Road OME…will the adapter kit come with this?
Looking to get some black wheels…any suggestions on where to get these for the scrambler?
I went with the ECGS axles…Dana 60 rear, Dana 44 front…60.5 width. What is the correct backspace for the wheels with this setup?
Nice work.
Not sure of your plans with your stock parts but you’d be surprised at what value some of it has. Be sure not to throw anything away without checking first.
(says they guy who threw away a Levi’s rear seat out of a ‘76 CJ7 ‘cause it was ugly and didn’t go with my interior plans when I first got into the CJ game about 20 yrs ago) 🫤
