What to do?
This tub has a DIY rhino type lining in it....any ideas on how to get this stuff off?
The thought at the moment is a LS 5.3, Dana 60 rear, Dana 44 front, 3.73, AX15, Dana 300
Solid choice. That's what I was going to do, and should have stuck with. Friend of mine did the same drivetrain but with JK Rubicon 44s in his YJ (still leaf sprung!) and he loves it.
Try heat in a spot with scrapper… kinda depends on how well it was prepared and what product used…
In order to fix this "the right way", it is over $3K in metal from a couple different vendors w/shipping.
It is a tough call as there aren't many left, but at the same time the aftermarket ones aren't great and now you can't even get them without huge delays in shipping, not to mention cost.
Delays! I ordered a cowl in April, received it in August.
Can’t imagine the delays for a whole tub.
Looks awful.....familiar.....
I tried the Citristrip on the tailgate to see what it would do.....seemed to work pretty good....it's messy but it worked.
it was covered with the DIY bed liner stuff....now on to the bed!
1DCB1FB8-9607-4BFF-BAD8-18AF64B66AB5_1_105_c.jpeg25140206-0B6C-4D42-ADA0-7F7A3FD949F4_1_105_c.jpeg
I thought I saw on this forum where someone put wider axles on their scrambler when they did an LS swap....but I can't seem to find it. Something like xj or tj axles....did I just make that up or is there a thread on here that discusses this?
And...is this something that I should look in to when doing a LS swap....for more stability?
Thoughts?
Thoughts?
I used a Waggy rear and a J10 front narrowed to match on my 82. WMS-WMS was close to XJ/TJ width. By narrowing the J10 front I didn’t have to outboard springs or lose turning radius. It handled great with a RE4.5 extreme lift.
My latest project 81 I kept the stock wide track width. But only 2.5” lift.
Got the bed all cleaned up and most of the seam seal out...moving slow but at least we are moving. Got some b-piller, riser, floor issues but got the metal ordered and must waiting on that for now.8720B337-EE39-460C-BE45-7E7ECE8FA54A_1_105_c.jpeg133D9FA9-69BA-4C95-8B87-CC903936CEDE_1_105_c.jpegBA6986FE-C0FB-48A9-A4A2-E1A5F1733CD2_1_105_c.jpeg343E35B4-84E7-4C41-B54D-EB657E3165CF_1_105_c.jpeg55650E41-39B8-4AE7-A84E-293C019AE08B_1_105_c.jpeg
Nice tub - you may not think so - but 1000% better than mine, looking good.
That is a fantastic start (as I've mentioned elsewhere though, I am fond of white Scramblers so I may be biased). Ilove the orange decals. Welcome.
If your budget allows, East Coast Great Supply sells complete, bolt-on axles. They do great work and it will make your project jump forward. I put a Dana 60 rear, 44 front with Eaton E lockers and disc brakes all around, 60.5" wide (YJ width). They come with all new steering tie rods and links. Then some Tom's drive shafts and my drive train was done with about a dozen bolts. Now she drives like a brand new car.
Interior: the Best Top seats quadratec sells are very comfy and make for a quick upgrade.
However, by far the best thing you will ever do in my opinion is to install a Painless wiring harness. It will save you countless hours of chasing electrical issues. I wish I'd done mine years ago. I was so impressed with their product.
And as Rob mentioned: pictures. Loads of pictures. The true purpose of this site is Jeep porn so post 'em up.
Would you suggest the 60.5" width with the LS swap or stick with the stock wide track?
I really like my 60.5 personally: no rubbing even at full lock and it's super stable. It's the same width as a YJ though so the rubber does stick out a bit.
I had wide flares before but I prefer the look of the stock flares. Here's mine with 285x75x16 and 8" rims and stock flares. Factory wide tracks would obviously prevent the rubber sticking out but I'm pretty happy with the look.
I’m getting the axles from ECGS….. I’m going with the Detroit TrueTrac on the front…what‘s your opinions on the rear…Detroit Locker or Detroit TrueTrac? Lemme know what you all think.
Going to be more of a road scrambler vs trail.
Thanks!
