- Greenwood
- MO
The thought at the moment is a LS 5.3, Dana 60 rear, Dana 44 front, 3.73, AX15, Dana 300Wow! Didn’t waste any time there. What powertrain did you decide on?
Solid choice. That's what I was going to do, and should have stuck with. Friend of mine did the same drivetrain but with JK Rubicon 44s in his YJ (still leaf sprung!) and he loves it.The thought at the moment is a LS 5.3, Dana 60 rear, Dana 44 front, 3.73, AX15, Dana 300
Try heat in a spot with scrapper… kinda depends on how well it was prepared and what product used…This tub has a DIY rhino type lining in it....any ideas on how to get this stuff off?
Delays! I ordered a cowl in April, received it in August.In order to fix this "the right way", it is over $3K in metal from a couple different vendors w/shipping.
It is a tough call as there aren't many left, but at the same time the aftermarket ones aren't great and now you can't even get them without huge delays in shipping, not to mention cost.
Looks awful.....familiar.....In order to fix this "the right way", it is over $3K in metal from a couple different vendors w/shipping.
I used a Waggy rear and a J10 front narrowed to match on my 82. WMS-WMS was close to XJ/TJ width. By narrowing the J10 front I didn’t have to outboard springs or lose turning radius. It handled great with a RE4.5 extreme lift.I thought I saw on this forum where someone put wider axles on their scrambler when they did an LS swap....but I can't seem to find it. Something like xj or tj axles....did I just make that up or is there a thread on here that discusses this?
And...is this something that I should look in to when doing a LS swap....for more stability?
Thoughts?
Would you suggest the 60.5" width with the LS swap or stick with the stock wide track?That is a fantastic start (as I've mentioned elsewhere though, I am fond of white Scramblers so I may be biased). Ilove the orange decals. Welcome.
If your budget allows, East Coast Great Supply sells complete, bolt-on axles. They do great work and it will make your project jump forward. I put a Dana 60 rear, 44 front with Eaton E lockers and disc brakes all around, 60.5" wide (YJ width). They come with all new steering tie rods and links. Then some Tom's drive shafts and my drive train was done with about a dozen bolts. Now she drives like a brand new car.
Interior: the Best Top seats quadratec sells are very comfy and make for a quick upgrade.
However, by far the best thing you will ever do in my opinion is to install a Painless wiring harness. It will save you countless hours of chasing electrical issues. I wish I'd done mine years ago. I was so impressed with their product.
And as Rob mentioned: pictures. Loads of pictures. The true purpose of this site is Jeep porn so post 'em up.
I really like my 60.5 personally: no rubbing even at full lock and it's super stable. It's the same width as a YJ though so the rubber does stick out a bit.Would you suggest the 60.5" width with the LS swap or stick with the stock wide track?
Will that work with a Dana 60 rear & 44 front?Old man emu YJ lift. None better.
You'll need the adapter kit for your frame but the axles will work perfectly.Will that work with a Dana 60 rear & 44 front?
