Where do you find good quality VINYL waterProof car cover?
Dave K.
Milwaukee
WI
Here's the deal--I need a vinyl type all weather care cover for my 2006 LJ and I've searched and only found the crappy "matrix" stuff--the cloth cover type. The vehicle has to sit outside for a little while and I want to get something which is waterproof, not water resistant as most of them claim. I've surfed and surfed and haven't found anything! Appreciate the help--heck, might be applicable to the Scrams as well!
My understanding was that they have to be breathable. The problem is that waterproof would trap water coming up from underneath (humidity/condensation) against the paint and bad things can happen. I have very limited experience here, but I do remember that detail coming up. FWIW.
Thanks, I just find that they become soaked and don't seem worth a darn in terms of protecting against moisture in the first place--could be wrong......
Hey Dave, BW is correct about trapping moisture. The top-quality car covers want to act like GoreTex and breathe while maintaining water-resistence from the top side. Although I don't have a lot of experience with this type of cover, I have seen the negative side of what can happen to vehicles in the Midwest when dew is trapped on the body for extended periods of time.
One cover I've often considered is a simple "Quanset hut" type structure built with simple 2x6 sill plates, some 20' lengths of 1/2" PVC pipe and an inexpensive standard plastic tarp. The PVC will easily bend into an arc with the feet anchored to the sill plate; a tarp stretches over the top and stakes to the ground or sill plate. This structure allows plenty of air flow around any object placed inside.
Here in the West with low humidity, I've been successful with just stringing inexpensive tarps directly over Jeeps using bungie cords. I imagine that you could do the same, if you were to remove it periodically (weekly) and pay close attention to the areas where the tarp makes contact with the metal body of your Jeep.
It is my belief that the best tarps are made of canvas and then treated on the top side to resist moisture, much like tents of yester-year, because this material will breathe. However, a good quality canvas tarp is pretty expensive.
I've had paint ruined by car covers...any wind and they rub back and forth on the high spots. The "Portable Garage" idea is the best.
