Which electronic ignition system is best for '81 258 6-cylinder?
DRdalequail
San Angelo
Preface this post with admission I'm a "1" on a 1-10 scale relative to being a mechanic. I often see recommendations herein to swap my ignition system for an "HEI". I perused Amazon and found a number available and they were not as expensive as what I'd reckoned, nor (apparently) as intricate for a novice like me to install. What mid-priced ($100) system might you recommend? Are they as simple to install as the ads claim?
The "1" on a scale of being a mechanic is a little concerning, and I'm not poking fun. Stabbing a new distributor is very simple...in premise...but even people like me, a self-acclaimed 8-out-of-10 on the mechanic scale, occasionally stab it 180 degrees out or mismatch plug wires and have to deal with the diagnosis of no start or violent backfires until eventually uncovering my oops.
If your rig is still running fine, I'd stick with a simple tune up of plugs, wires, and coil. The HEI (high energy ignition) coil-on-cap upgrade is usually for simplicity because it has the mutli-spark module in the cap instead of built into the dreaded "ignition module" that leaks potting sap on the fenderwell eventually. There is also the option of the "nutter bypass" which retains a lot of the main components but cleans things up a little bit.
As for the $100 scamazon HEI dizzy....I'd steer clear if it's your daily or frequent driver. I've run the cheap HEI dizzys on dedicated off road rigs, and the fit and finish isn't great. I had one in a 351M powered '78 Bronco, and the clearance on the base was so loose that the distributor would literally dance around as the engine ran which eventually started to wear funny on the cam gear. Buy nice or buy twice, as some would say...
I am running a DUI brand “HEI” distributor on one of my jeeps. It’s a very high-quality distributor, but the price point is a bit higher. Well worth the money IMHO!
Here is a good link to the TFI and HEI upgrades.
There is also some additional information on the site, including a vacuum diagram :huh:
http://keith.cj8.tripod.com/tfi_upgrade.htm
Before spending money on "upgrades", I would verify that what I have is working correctly first, and become more acquainted with how the ignition system/timing/vacuum/mechanical advances/carburetor adjustments/engine compression all have to work together to get a good running machine :twocents:
The OEM components, if working/adjusted correctly, will perform great, even the later computer controlled BBD systems.
I would put my bone stock 1985 CJ7 (full CA emissions package with computer controlled BBD carb), which is adjusted and working correctly, against any rig with swapped in HEI/Motorcrafts/Weber carbs any day of the week :twocents:
Don't believe me, ask JeepAddict. My poor '85 has been locked up in his warehouse since April/May, neglected. All he has to do is hit the gas pedal once, bump the key, Jeep starts right up and runs great :headbang:
I believe DUI was the first to market a HEI setup for the 258. Not cheap but not crappy import stuff(maybe be imported but not crappy)
