Will 33" tire fit swingout tire carrier?
Scramblin_Jim
Goodyear
AZ
I am upgrading to 33x9.50xR15 tires BFG T/A KO's. I have the stock swingout tire carrier mounted to the rear of the Jeep. Been running 30"x9.5R15 Goodyear tires and same size spare mounted to the carrier without problems.
1. will the tire fit as a spare using the same 8" wide rims?
2. will the added weight cause the assembly over time to rip off the body mounts?
I don't think so and I certainly wouldn't trust it with all that extra weight even if you made it fit. You want to have another option.
You don't want it coming loose and smashing someone behind you... throw it in the bed or get another mounting setup.
It fits, I had 33s on stock rims the spare fits but it is a little tight and mashes in the rubber a tiny bit.
I had a 33 x 12.50/15 on a 10" rim on mine for a while. It fit and seemed to do OK. I was concerned about the weight, so I built a bumper tire carrier combo...even it broke after 3 years of use. I repaired it and am still using it.
It will tear out your sheet metal after awhile (I've had sheetmetal tear with a 31x10.50)
Contact Scott Anderson here and have him make you a bumper/swingout carrier. He is very reasonable pricewise and the bumper he made me looks great and is very strong. I'll post pics this weekend. I painted the thing a few weeks ago and have been meaning to do it anyway.
Trying to understand the physical problems: Is it too hard to get in behind the mounts to beef 'em up? Not enough room??
Thanks all for the feedback.
The weight pulls on your sheetmetal and it will eventually stress and tear. Mine sheetmetal is torn on one Jeep and the other has been fine so far, but again, that's with 31's. You could put bigger backing plates in there I suppose, which would spread the load out over a wider area, but IMO the only way to do it right is to mount all that weight on the frame where it belongs, instead of on your sheet metal. The stock carrier is fine with the stock size tires, which were 235/75/15 (a tiny bit smaller than what you've benn running), but it's not really designed to hold a bigger/heavier tire. You might run it for years with a 33 on it and not have any problems OR you might have the sheetmetal start tearing where the carrier bolts up to the body.
The bumper/ tire combo Scott made me has a receiver hitch, dring brackets, and a removeable tire carrier all supported by the frame, so I killed several birds with one stone doing it that way.
My old scrambler and the one I just completed have had 33's on the factory carrier and no problems. My plain is to have a a buddy make me a nice heavy duty swingout carrier.
OK, finally to pictures of my painted bumper Scott made me. It's 4x4, tapered on the ends, has a REMOVABLE tire carrier, Dring mounts, and a receiver hitch (I added the hitch, but when I picked the bumper up Scott was working on another identical one with an integrated hitch). Price was very resonable, and the quality/ strength is much better than Warn etc for less money. This takes the weight off of the tub and puts it on the frame, and bolts right onto the Jeep with no modifications. I got some 1/4" angle iron tied into the frame so the frame, not the rear crossmember, is holding the weight of the bumper/spare.
Pics are of bumper Scott made and the frame tie in "brackets" (brackets are simply angle iron with holes drilled).
Bracket pics are attached in this thread....
https://www.cj-8.com/forum/showthread.php?t=16476
He's done with my side steps/ rocker guards now so ya'll can flood him with orders......
It will fit. If nothing else, stack a few washers on the studs to move the tire out a bit. This is what I did to fit 35x12.5 tire on my stock tire carrier. However it was not long before I noticed the sheet metal around upper hinge begin to fatigue so I removed the tire along with the carrier. There really is not much that can be done to reinforce the tub.
In the near future I will either have one custom made locally or buy one from Eddie Reighard. His work looks quite impessive. He goes by the name BESRK on Jeeps Unlimted and sells his bumpers and tire carriers as gpfab on eBay.
wm69
Did you empty all of those ammo cans? That'd be a bit of shooting.
I wish. I got out of the shooting game when ammo tripled in price a couple years ago. I'm hoping gas prices don't do the same thing to my Jeep hobby. I got the cans for $2.00 each from a guy who bought a whole pallet of them. I repainted them (krylon fusion I had left over from painting my M416 trailer)so I've got about $2.50ea in them now. At that price I couldn't pass on them (bought 30 of them). I use them for all kinds of stuff.
I keep accumulating them, not as fast these days. The reloads that I buy always come in them. It's gotten to the point, I tell them to keep the can sometimes. I'm shooting more .22's these days, easier on the wallet and my arm. I might have to paint some of mine, those look pretty good.
Those were in good shape, but they painted over the markings with red paint. I'm a bit OCD so I took that Fusion paint and sprayed them. $5/can at chinamart or autozone, and 1 can will do 6-7 cans easily (I painted a few on the inside too, after I cleaned a bit of light rust out of them).
