Will a 4.0 clutch bolt on a 401 flywheel?
Going Postal
Corvallis
OR
Trying to figure out which clutch to order for my 401 to NV3550 swap. I'm using a 2001 Wrangler NV3550 complete with it's bellhousing, throwout bearing and arm. Part numbers are different between the 4.0 and 401 pressure plates but the disks are the same. I'm thinking this is due to teh design of teh 4.0 throwout bearing and arm assembly for the hydrolic clutch.
So... I'm just wanting to confirm a 4.0 pressure plate will bolt to the 401 flywheel. If it does the only other issue would be if the 401 and 4.0 flywheel surface is in the same location in reforance to the block to bell face. I'm worried that the clutch reliece arms wont be in the same location when bolted to the 401 flywheel and I'll have engagment issues with the throwout bearing.
Just use the 401 clutch, the difference is not the throwout bearing size as much as the spring strength of the preasure plate.
Dont worry about the release fingers on the preasure plate being different either.
It would be a good idea to measure the engine block bell housing mounting surface to the clutch release fingers and compare the two (401 vs 4.0L) just to be sure the offset is close, if its within 1/2" or so it will be fine.
(if you can, assemble the clutch to the flywheel, flywheel to engine and measure, that is your most accurate way) Worst case, you may have to adjust the external slave cylender position to get the right amount of throw and release is all.
Also make sure the Pilot bushing diameter in the 401 crankshaft is the same as the nose on the transmision input shaft.
I think you will find mating the NV3550 trans to a 401 will be easier than you think.
Hope that helps
That does help thanks... Will a 401 starter bolt into a 3550 bell and work with the 401 flywheel then?
Now thats the one thing you will have to really do some work with.
First, Count the teeth on both flywheels, and measure the diameter and circumference.
There is one thing you have to remember, you cant swap flywheels.
The AMC401 flywheel is balanced ONLY for the 401 engine. Dont try to swap another flywheel onto it unless it has been ballanced for the 401 as well.
Ideally, the flywheel diameters, circumference and tooth count would be the same so at most you may have to shim the starter or something like that.
The worst case would be that the 401 flywheel is smaller (not likely though)
Take some pictures, do the measurments and let us know what you find out and we'll go from there.
everything will just be speculation untill we have that information
What about rebalancing a flywheel? I just realized I have a 94 OBD I 4.0 flywheel in the garage and my 401 has a flex plate on teh back end of it. Couldn't I take them both to a machine shop and have the 4.0 fly wheel balanced to match the 401 flexplate?
I don't know about using a 6-cylinder flywheel, but I did have a flywheel for a 360 rebalanced for a 401. Take it to a competent machine shop, explain that the AMC V8s are externally balanced, and see what they!
You will need a AMC V8 flywheel. The 304 has a 'Zero' balance to it and they are common so you could probably get one of those easily enough.
then, take it to a GOOD machine shop to be balanced for the 401.
Most of the Old School shops will be familiar with how AMC balanced thier engines.
This is a good time to work out the starter issues befor you spend the money on a new flywheel.
This is what you want to end up with ultimatly:
The flywheel needs to be the same diameter of the NV3550 flywheel and have the same tooth count. (so you can use the starter that bolts to the bell housing)
It also needs to be close to the proper wieght of a 401 flywheel and be externally balanced for a AMC 401 V8 engine. (so the engine runs properly)
Then you can have the clutch presure plate mounting holes put in it for the 401 presure plate if they dont already line up/are the wrong size. (dont forget the positioning dowls pins for the presure plate AND THE CRANK SHAFT DOWL PIN)
This is actually going to make it easier, but it may cost a bit more money.
Ordered all my parts today. :) Should be diving into the complete swap just in time for Christmas! :)
