Winch
VinnyM
Rolling work in progress
Martinsville
NJ
Ok, I have decited to buy a winch. A Ramsey rep 8000 to be exact (Northern Tool has them for 650, and since I did not get any good toys for christmass). Other then the winch and winch mounting plate what else in a must have.
What about the, Winch On - Off Saftey Swich(under hood kill swich I gather) , or the Dual Battery Isolator.
Any thoughts appreated.
Vinny
WINCH
Vinny if you havent already bought it shop around,I've seen that same winch for as little as $400.00 without the hause or rollers on it.Dual batteries will depend on how much you use it or how much other stuff you have drawing on your electricl system.I run a single battery on mine with a 95 amp alternator and have never killed the motor winching it,the big thing is winch a little and let the battery catch up, even with a dual battery set up don't do long winching sessions unless you want to burn the motor up on the winch and melt your cables."NEVER" hook the winch leads up to the side post of your battery,you will melt the post out of the battery.As far as a "cut off" switch that is personal prefence,it's not a bad idea to put it where it will kill the entire electrical circuit,I have quick disconnects on mine that you can get from any marine dealer.-JC
OOPS!
Yeah, I've got my cables hooked up to the side terminals on my optima and haven't had any problems. Only use my winch occasionally, but haven't had any problems so far....
How Long Is Long?
Dumb question but, what would you consider a long session? 2 minutes, 4 minutes...?
HOW LONG IS LONG
I've seen High Dollar Batteries ruin the first heavy winching session with the cables hooked up to the side post,I've seen more than one with the side post melted out of the battery,How long depends,are you winching up a steep rock face or just a slick spot,a deep mud hole or just winching another rig up a hill? The best advice i can give on that is watch your alternator/volt gauge,have someone feel the winch motor from time to time,there are a lot of varibles that play into "how long",are you winching a dead load or are you driving it in 4wd and helping the winch? All these things come into play,It's kind of a judgement call on how long,experience will tell you.One other piece of advice,make sure and pull 10 or 15 feet of line and winch it back in about once a month,this will keep the winch working and keep the contacts in the motor from sticking-JC ;)
If you are going to pay $600 for a Ramsey, spend a couple dollars more and get a warn. A friend bought one of those Harbor Freight special, and while it is better than no winch, it is very slow, and this was just winching a wagoneer on a trailer. Would hate to have to wait on this thing pulling someone up a long hill. Make sure you look at line speed and amperage draw on the battery. If you plan on doing a lot of winching (more than once a month), go ahead and get the warn, you will be thanking yourself the first time you see someone do a pull with the Ramsey. If you are having one "just in case" and don't think you will use it, than the cheapo will be just fine for you.
I run a single Die-Hard gold battery and have never had to wait on the battery to catch up. I have pulled a 15K lb truck/trailer from ditches where I did 80' pulls at about 75% load followd a few minutes later another 60' pull. Generally, I find the battery will handle a single pull and then will be recharged while you move equipment and set up for the next pull.
Using it all the time!
I have had winches on almost all my Jeeps and if you wheel often, you will use it! At least i do, almost everytime i'm out. I'm glad i got one. I think the advice that has been given so far is very good. Get a good one, i 've used Warns and they have given me very few problems.
The best prices I've found on Warn are at Telico 4X4 and Clemson 4X4. They both ship for free (at least included, haven't confirmed this lately) and have the best prices I've found. They have them in stock and ship quick, too.
Ebay
I don't know what's on there now, but when I bought my Warn 9500i about two years ago, I got it off of EBAY.
there was a guy selling them for $700.00 or you could add $100.00 and he threw in the mounting plate and hardware. FREE SHIPPING.
Sometimes it is worth checking out as some sellers will actually sell lower and sell more....or something like that.
Thanks everyone.....intresting coments.
mules, if hooking the winch to the side posts is bad, where do you have them connected??
FYI...looks like the Rep 8000 discounted, replaced by the 8500e.
As for who winch is better, well i'm not going to settle that one...lol
Vinny
HOOK UPS
You need a dual hookup type battery with the top post and side post,use the top post for the winch they are much larger than the side post connections and can handle the high amp loads that the winch will put on them.Use the side post for the jeep starting circuits.-JC
