woohooo I now own a 2nd Jeep
Come and see me.
I have an extra set of CNC dished Silovite pistons for a stroker. They are done to allow you to run 87 octane without pinging. Got lots of other stuff that will work too.
How bad is the body? There is a guy here in the club that has a YJ tub and frame with no Title that might make a good candidate for you if you need.
Carl
Good to hear that you are mostly well too.
That YJ should have a 999, the AX-15 is a 5 speed manual that replaced the T-5.
I have a complete engine and Trans sitting in the garage that you can look at. The only real difference in the YJ 999 and the CJ 999 should be the stickout distance on the Transmission. The NP 231 t-case needs more depth. This is easily solved with a clocking ring, and/or spacer. I think it needs to be 3/4" Got to check that though. Otherwise a pretty easy bolt up.
It will be nice to have an injected 4.0l in the Scrambler. Pretty easy to do that conversion. The 91-95 YJ is the absolute easiest one for that swap. Also you should look seriously at doing the Stroker while you have it out.
Carl
Glad to hear you made it out okay. That had to have been one heck of a shock.
The YJ should be a 904 transmission instead of the 999. Same case, just different internals, fewer bands. However, still a strong enough transmission for the 258, even with the upgrades. Supposedly you can upgrade the 904 to a 999 when you do a rebuild, haven't confirmed it though.
Have heard about the output shaft length too, but my understanding is that any clocking ring provide enough spacing though. The thinest clocking ring I think I've seen is 3/8". Novak would be the one to check with.
Good luck with the new project.
Damn the bad luck
Me and the little woman were waiting at a stop light when a full-size Ford flew through a red light, hitting another lady that was turning into what she thought was a clear lane, and "bam" the Ford pinballed off of her into us.
I am sooo P.O.!!!! Thankfully we weren't badly hurt, just some whiplash. But the Toyota Avalon was/is an 06 that may be totaled.
Iv'e just had enuff of STUPID drivers not paying attention. Sorry, not to Hi-Jack,....it just sucks.
Wow...that was a hard hit. Glad you're ok!
What happened to the motorcycle driver?????!!!!!!!!! :eek: Wouldn't he have gone through the back end of the hard top?
That's insane! Glad you're ok... wow.
Hope you can make something good happen out of all of that... damn.
I'm looking into doing the same kind of swap... only the other way around. I picked up a YJ for a deal and also found a D300 along the way for another good deal.
Now, I am contemplating ditching the NP231 for the D300. What I have found so far is that the shaft of the TF999 or same exterior 32RH tranny from the YJ doesn't have the proper shaft length to mate to a 300. It will bolt up but you need an extra length added to the output shaft of the YJ TF999. Keep in mind the extra length is only ~1/2"!!! But from Novak that ~1/2 will cost you $179.00!!!
I guess you'd be better off either getting the CJ style TF999 if it came cheaper than the adapter at that point... decisions decisions
