Wow, never seen this before...
RubberDuck
Baltimore
MD
I was up at the transmission shop today picking up my Scrambler (needed a pesky leak tracked down) and the guy had an LJ up on the lift. He said if I had a second he wanted to show me something. We went underneath of it and there was a giant jagged torn hole in the floor above where the transfer case **used** to be :huh: . He then showed me what was left of the T-case. Apparently the drive shaft snapped going 70mph on the highway, then caught on something and ripped the T-case off the transmission and it came through the floor and almost took the guy's feet off!
To add insult to injury they couldn't track down a used t-case anywhere and had to drop $2000 on a rebuilt one from Mopar I believe.
And the picture is where now?? ;)
[Mr. Makey voice]Driveshafts coming loose at speed are bad.[/Mr. Mackey voice]
I know, as soon as I was rolling down the road I was like "Damnit, picture!!"
It Happens
1977, Dearborn County Fair Grounds. Dirt/Sand drags. Had someone else driving my racer while I was using my new fangled Super 8mm with SOUND! Just had back surgery. Bob left the starting line.....front ring& pinion broke....locked up...left front locking hub exploded while at the same instant the front drive shaft broke... Drive shaft dug into track snapping transfer case off along with part of transmission... Trans/transfer dug into track forcing rear 44 pinion into housing completely destroying all internals and breaking housing as spring locater pin snapped allowing assembly to slide back spring far enough to destroy brand new Paddle tire.:banghead::banghead::banghead:
Result: I was so upset, the owner of Western Hills Jeep gave me the keys to his service department and told me to take the Jeep up there and he would repair it along with sponsoring me with a new race engine. We ended up putting the "Factory" Jeep race team on the trailer more often than not. :D ;)
Life is good! :thumbsup:
:wave:
