bigjeepnfool said:I believe the first year of widetrack axles in scramblers exclusively was 83(not positive but 82's are mixed from what i've seen) but i know they used narrowtracks on early scramblers 81 and 82.
hope this helps,
-Will
Cj8er said:Well, not sure why yet but my '81 is WT on rear (57" wms/wms) and NT on front (54" wms/wms). I've emailed PO to find out if he put rear axle on later but have not heard back yet. I figured they were both WT as they don't look any different, but I measured to make sure. Or maybe this was a mixed year where they put on different widths until they used up all the inventory.
Thanks,
Drew
(Stranger things have happened... ; .)Drew - I think I can use some wheel spacers to bring the front out a little to match the back (FYI everybody else...Drew and I are working out a swap). I'm doing a little research on that now.Cj8er said:Well, not sure why yet but my '81 is WT on rear (57" wms/wms) and NT on front (54" wms/wms). I've emailed PO to find out if he put rear axle on later but have not heard back yet. I figured they were both WT as they don't look any different, but I measured to make sure. Or maybe this was a mixed year where they put on different widths until they used up all the inventory.
Thanks,
Drew
WildTurkeycj8 said:Drew - I think I can use some wheel spacers to bring the front out a little to match the back (FYI everybody else...Drew and I are working out a swap). I'm doing a little research on that now.
I just went out and took the wheels and tires off my widetracks. The best measurement I could come up with was WMS 56" rear, WMS 56.25" front, but that was with nobody else holding the other end of the tape measure so that may be off just a little.
-Mike
