Xenon Fender Flares
Going Postal
Corvallis
Anyone know of a write up of Xenon flares that showes how the rears look? Anyone have some pictures they can send me?
Thanks...
I don't have a write-up. On the rears, you have to cut the lip off that sticks out the back, so that you have the flat flange to work with. Don't trim this part off until you figure out just where you want the flare to sit.
Xenon
You can look at my attached pic in the Drivetrain forum under Front SOA Springs. Xenon front & rear. I'll try to retrieve it & attach here.
Robert
Thanks guys,
Do you know if I would need to trim or remove my stock chrome rocker cover?
AKCJ8 said:
Thanks guys,
I don't think you'd have to, but I took mine off and have 4XDr rocker guards, same as Crossbones.
Xenon flares
I have the Xenon Flares on My Scrambler too, They are the same as YJ rear flares that as forementioned you have to trim. They stick out pretty far! I saw a Scrambler with what looked like the best top flares on it, But I havn't had time to track it down, I am thinking about changing mine out for them if I can find them. i like the rounder style of that flare. If I find them Mine will be available.
Digging up an old post, but felt like it was the best place to start. Could someone that has installed the xenon flares take a picture of the backside of the flare so I can see where I need to start trimming the plastic?
John mentioned not to start trimming till you know where to you want them sitting. Any reason not to just trim off the complete lip so you have a comple smooth edge to work with?
Mine came in last night and I would like to get them test fitted before I paint the Scrambler this weekend.
Eric the lip has to be trimmed flush to the mounting surface. Then some of the mounting surface had to be trimmed to match the fender opening.
Robert
Go ahead and cut the lip off, it won't work anyway. Then you have a flat surface to work with.
Thanks, I think I understand the process and what needs to be trimmed and where. Will look at it again tonight and hollar if I need more help.
creepy... [edit: forgot the 'y'! didn't mean to call you a creep! :D :D] I was out last night working to figure out how I was going to mount mine too! :D
I have the issue of not having ANY of the metal that they are SUPPOSED to mount to. I decided that I'm going to have to simply drill and tap holes in the PSC corners to get them on. Good thing is that it's more tire clearance ;)
Knew rust was good for something!
