XJ DD to be totaled, need help...
Ok, the adjustor came to look at it today and unfortunately I couldn't manage to be here. He called me right after it though.
He went on to give me an amount for the repairs without any comment other than "I don't think we'll have to total it" (I'll be very surprised if his estimate of the value of the XJ holds up, I was shocked how much he mentioned). Needless to say, this was surprising. So I asked "So you think the front corner can be repaired? I know that it's a unibody and that damage to that is bad."
He replied "Yeah, they put it on a puller machine."
I didn't press it because I knew I'd talked to the shop that I'd take it to and that they wouldn't fix it due to the "liability issues". They said that many good shops won't touch unibody damage because of the number of lawsuits that have been filed recently against shops after unibody damage was repaired and then the vehicle was involved in a major accident. Apparently lawyers use the repair as an excuse to sue the shop saying that it weakened the vehicle.
So I'm going to drop it off back at the shop for a formal quote on Monday, then wait to see what the ins. company finally decides. I talked with Joe and he says that this is coming up all the time now and that they've had to tell a bunch of ins. cos that they had to total a vehicle that they initially quoted repairs on.
I'll get pics in the daylight tomorrow to ask your opinion of the damage...
WildTurkeycj8 said:
Eric - I talked to a friend of mine tonight that has a 1988 XJ that (he says) is in very good shape except the Pugeout tranny is blown. 4 door. he only wants $350. If you want more info on contacting him, etc. let me know. I have never seen the jeep, but am planning on going to his house tomorrow night.
-Mike
HMMMM, a little older than I would hope for but damn, that could be a great deal if it's in good shape. I actually have a 21-spline AW4 sitting in the garage and another with a NP231 with the tera-low 2WD low conversion attached to it sitting in my parts XJ at Lee's shop!
Definitely take a look at it for me man if you don't mind! If you can start it up and check out whatever you can, I'd owe you! Pics would be great too cause I'll have to show Kate...
Pics
Here's the pics finally (new nephew showed up yesterday so I wasn't around). Sorry, they're large...
No comments on the square tube bumper, it was a freebie and died a valiant death. It most likely wouldn't still be drivable and still have a salvageavble 4.0 if I'd had the stock sheet metal POS bumper on there. Impact would have basically been square in the middle of the grille and would have pushed everything back through the radiator into the front of the engine. Would have been stronger with a winch bolted in, but of course the winch would be toast and the grille and the surround (even though it's cracked in the lower right corner) wouldn't be reusable and the radiator might have taken a shot from the top of the winch.
You can see that the bumper bracket just pushed the right front corner back and up, crunching the "framerail" and tweaking the entire front crossmember.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Is that the extent of the damage? No other buckling of the frame? Does it drive nice and straight?
That really looks minimal to me. I certainly wouldn't expect it to be "totalled". I might not even make a claim depending on your rates. Just have the ins. co. pay on the liability and weld a new bumper on. Buy a replacement airbag from a salvage yard and you are back in business, or just put in a non-airbag steering wheel. Or make the collision claim and let the ins. co. pay for everything. If that Jeep was a good runner before and they can fix the cosmetics and airbag I would certainly let them do it.
Later,
Not a chance...
I can't see any other damage (buckling or whatnot), However, maybe it doesn't show up in the pics, but that crushed section is about 4" back from where it should be. If I were to "weld a new bumper on, it would be VERY obviously cocked back in to the right and the entire right front corner is jacked up at least an inch. Putting the hood down really showed it and the right front door sticks pretty well. Looking at the front, it's easily noticable that things are cocked up on that corner.
So, while it's not totally smashed in, the right front is well off from where it should be and truly making the badly damaged part of the "framerail" right would require cutting off the front end and welding in a new section.
The Jeep now has a noticable pull to the right that wasn't there at all before.
Regardless of what it looks like, the fact is that the repair is something that my chosen shop won't touch. This is what my wife and baby will be riding around in on the road every day. I'm thinking replacement rather than repair the more I think about it.
I flip flop on this about every 15 minutes.
We REALLY like our XJ, but unibody repair scares the hell out of me as an engineer....
I'd love other opinions on this, I'm trying to research it as best I can on the web.
Well if the frame is actually damaged other than in the first 4 inches, than I would probably look for a replacement.
If it is just the frame horn, then probably all of the sheetmetal attached has been slightly tweaked. I would think that the panels could be easily realigned. If I was going to put a new bumper on, I would make a tab and weld it back on the straight part of the frame and align it with the good side so it would be straight with the grille.
I don't think that frame would be any less safe if repaired properly if it is only the front 4"s like you say. If they put it on a frame machine and it is out of line in any other spec, than that is different.
I know that I wouldn't want to put my family at any risk. My wife had similar fender bender in her Expedition probably less impact. It did over $1000 in damage. Most of the damage was behind the bumper cover. I popped out the bumper cover and that was it. It looks like a ding where it was smashed in. There is still damage behind, but it doesn't affect the safety of her vehicle.
Good Luck,
Just heard...
Ok, it still has to have managment review/approval, but it looks like they're going to total it out.
They're estimate is right at 75% (the limit in NC) and they know the shop estimate will likely come in higher so they allow for that in the calulations in the cost.
Totaling it out in NC will require it to carry a salvage title, but it's just a form we send in when we do the paperwork to settle with the ins. company there's NO inspection :D
I could care less about the salvage title as 1) I would have disclosed and pointed out any repair anyhow and 2) if I were to ever sell this, it would have almost certainly been to a Jeeper who wouldn't care about the title, only the condition of the vehicle and the quality of the repair.
If the numbers that he used hold up, I'll actually be pleased with the amount as the XJ has a number of minor cosmetic issues (dings, chips, interior blemishes) that could have been reason to go with the low-end of the market value, but they're putting it right square in the middle (I couldn't bring myself to argue for the high end as I can't realistically make a case to do so).
Now we wait for the buyback number...
Hey Eric,
So glad no one was hurt or injured. Glad everyone was safe. Unibody damage is not that big of issue if it can be fixed right and supported. The main issue is: Was it damaged or bent any where between the axles? This would include the engine mount area and how well it drives. If they are going to total it may have had other damage than that first part. I have owned three salvaged vehicles. One Suburban, one Ramcharger and one Trans Am. The Trans Am was Uni and was hit hard on the front. The Uni was bent pretty good. I bought it back when totaled and had it repaired. It drove nice and I never had any problems. I later had another wreck where it was "T-boned" on the drivers side. That time it went to the junk yard but it stilll held up in the crash very well. Or i should say as well as I expected it. I know I have fallen in love with my XJ and would hate to loose it.
Alright, I think I've gotten this figured out. Now that I know for sure that there's no inspection to get this back on the road, I think I'm going to let Joe take a shot at it.
If I don't feel good about the repair, I can sell it off as a trail rig and put the cash toward something new.
The settlement is really pretty fair, so I should be able to take care of Joe and get anything needed to make the repair work.
I'm thinking that a real stout bumper, Joe's reinforcement and maybe a set of frame stiffeners will do the trick.
I'll have to look harder, but I really don't think that there's any damage other than what you see in the pics. It makes it down the road in good shape with the exception of a slight pull to the right.
I might settle this out tomorrow, time to call Joe... :)
Oh YEAH!!!
Now I'm REALLY ok with the idea of fixing my salvageXJ!
Came across this WNC bumper while searching on NAXJA. I think it's the best looking bumper that I've ever seen for the XJ. Best part is that it requires cutting out the front crossmember that's already screwed! It bolts back along the "framerails" and looks monster stout.
I'll be talking with them tomorrow about trying to get one ASAP. :D
forum
Let me know how much that thing costs... and see what the price is if you buy 2.
THAT is a great looking bumper for an XJ! While not trashed, my DD's front bumper is tweaked. How 'bout asking them if they'd 'sweeten' the price if you bought two... since I am in no hurry, we could have both shipped to you and I could p-u later. Do you have any kind of price range on it?
Would you mind?
Isn't it????
Hmmmm, I was thinking about going out there to pick it up.
In theory I could save you some shipping if you split the cost of the gas out and back with me but I'm in a big hurry to get this as I'd need to have Joe cut out the crossmember and I'll need this to make it roadworthy after he's done. In reality I'd like to have it for him to fit up as he's pulling on the frame to ensure that it will mount properly with the reinforcement that he wants to add in.
This is a made-on-order type deal, I read that they do about one a month, so it might not even work for me to get one in time to do all of this (which would SUCK because I have my heart set on it now...) maybe I could dig up a stock front bumper for the time being and get this when I can...
Let me talk with them tomorrow man, I'll get the scoop and see what we can manage. Post back and let me know what you want in the way of options (if any), check out their site, they can add a stinger and inset fog lights.
Those are nice. I seriously looked into those when I bought mine. When I talked with them the bumper was $400 with D-rings. I think you got a great plan there Eric. That sounds like the one you need. I really like the hidden winch. I hated the idea of cutting my good crossmember though out so I went with Rigidco for the front and rear. I tried to post pics but for some reason could not.
Dan
attachment.php
forum
I have a front bumper off of my '95 XJ - black w/ end caps - normal wear and tear, never been kissed - if you (or Marine) need/want it.
Stouttrout said:
How does the tire carrier latch? I like the looks of that rear one and it would match pretty well with the front one from WNC. Looking at the funds, it seems that I'll be able to manage something to match in the rear, especially if I sell off the FourReal bumper/tire carrier that I have on it now.
Also, does it connect only to the rear crossmember (where the stocker bolts) or does it have something that runs under the "framerails" to pick up the tow hitch bolts too? I really like the idea of one that does that (like my current one).
I also want to thank everyone for all of the help, advice and offers of assistance/parts... it's been a great help!
I'm PMing with the fabricator at WNC to get this going and offered a generous (I think) bonus for quick delivery. We'll see what happens.
Jerry, I did mention that you wanted one too, but given that they are making them one at a time and that I need mine ASAP, I don't know what we'll be able to work out. I'll keep trying.
Wow! That is a sweet rear bumper!
bigwalton said:
I like the looks of that rear one...
No sweat Eric... The +/- $400 price tag is more than I have right now. I probably spouted off quicker than I should - I just really liked the way it looked. But before I go gussying up my DD, I need to get my Scrambler back 'up', not to mention buy a house (with enough 'space' to store my collection :eek: ).
Godspeed in your bigger, stronger, etc... 'rebuild'. :)
It has a bolt on latch. Out of all the latches i checked into for the scrambler, it seems a good old bolt is the one that works best without any rattle or failure. Ever. One the 8 is no problem to undo. Takes just a few seconds thats why I did not mind it on the XJ. Check out Ruggedjeep's post on NAXJA. He has awesome pics and yes it is well supported. He show pics of that as well. Check out those sweet endcaps too.
http://www.naxja.org/forum/showthread.php?t=71610&page=1&pp=15&highlight=rigid+rear+bumper
A bolt latch could work on a trail rig, but not on a DD. The one we have now is a bolt and it's just not acceptable for daily use (think stroller). It will have to be a lever latch or nothing.
We're going to hold off on the rear for a while anyway.
With your collection, Maybe you should looking at buying a garage with a house attached. :)
Maybe somethign with a little loft above, and a small fridge. Well OK big fridge.
Seriously good luck in the search.
Also Eric that bumper looks great. Looks like you got a fine trail rig developing there. You should be able to just order the Air bag covers from DC, espically since this is going to be off road only.
Carl
