Well, I ended up switching to early YJ seat brackets, as the YJ passenger side was WAY too high with the Liberty seat setup (including integrated seat slider). I got the driver side mounted on the YJ bracket, and it looks NICE! The swap is REALLY simple.
1) Unbolt the one side of the Liberty seat bracket
2) Cut/grind off the other side of the Liberty seat bracket
3) Drill one hole in the bottom of each seat slider (on the Liberty seat), and use the existing YJ seat bracket holes.
4) Buy a few bolts & nuts.
5) Wa-lah...done.
It has to be one of the easiest late-model seat swaps, I'm guessing.
It is taller than a YJ seat (I compared against my '94), and it slopes a little more front to back (seat isn't as flat as a stock YJ seat). The photos below show it mounted to the seat bracket, but just sitting in the Scrambler. I will need to use a Dremel tool to carve out a little of the plastic side piece on the seat, as it interferes with the flip-forward latch on the seat bracket. The seats are also a little dusty from sitting in the shop where I got them, but I'll clean them up shortly. What do y'all think?
I'm going to swap it into my YJ this weekend so I can get a feel for it (since my Scrambler isn't going to be running for a while). I'll let you know how it works.
Craig
