Project Postal...on steroids...
LOST
I drive the right side.
Talkeetna
AK
This is the beginning of my write-up of project Postal.
I have owned about eight of these over the years since the auction...
In 1994 the Post office auctioned off their right hand drive CJ-8's for a starting bid of $2500..That is where I got to "see the light and drive on the right" so to speak. I added a 4" lift shackle reversal new custom front end and changed the brakes and seals to DOT3 from DOT5 (don't add one to the other it will eat the seals).
Well it wasn't enough for me I wanted to go big, I mean really big, so this is the beginning....
Stock 1984 RHD CJ-8
I ordered a new steel tub because the original was rusted beyond repair, I had to cut and grind to salvage everything...
The new tub firewall had to be removed and replaced with the stock RHD one....
Then I found out that the frame was rusted way too bad so I cut the front off and sent it to Advanced Frame Works to have a custom mandrel bent RHD frame, set up for YJ springs, shackle reversal, Chevy motor mounts and galvanized...The first bling bling...
Firewall swap, not the cleanest photo...
Next the rear was tubbed for a CJ-7 top...Then the tailgate is mounted and welded into place (not finished in this photo).
This is great Lost... getting another one of our "Sweethearts" up from the grave!! :D Looking good. Keep the updates coming.
z
btw what kind of packaging did the AFW frame come to you in?
Lost, looks good are you doing all the work yourself? I was at the auction in Anchorage and I remembered some of the Jeeps going for as little as $800. I wish I could have bought and stored some of the stock sheet metal and other goodies they were selling by the bin load. Keep the updates coming.
Truck
I have been waiting for this thread ever since I saw the rolling chassis sitting in your shop!!!
Oh man, no World Cab top? I knew you weren't going with the original pivoting rack deal, but I didn't know you were going away from the top altogether?
Still want to see the build! Keep it coming.
Great thread. I just heard of an Alaskan Postal about an hour from my place, and will be trying to check it out soon. :)
Craig
Dean - It's looking great! Thanks for the update!
BTW, not to hijack your thread, but just wanted to let you know that we got the adapter and t/c that I bought from you mounted up this weekend. Drilled some new holes in the adapter so we could clock the t/c. I really need to post some pics and a write-up on my progress this week!
Later
-Mike W
zero2wow...The frame was stap-tied to 2x4's if I remember right...
Truck...I missed the auction and picked up mine the week after, they still had six of them and I got my pick for $2500. I have always been told they went for that. I also had a arctic pad for the rear at one time.
WildTurkeycj8...glad to hear you have your project going!!Keep us informed.
Well on with the trimming...
The wheelwells were next...
First I trimmed the little lip off, then I V-notched inbetween the spotwelds, heated them and pounded them in. Welded them one at a time measuring as I go and cooling them with ice to protect from warping (the advantages of heating and welding in winter).
I started collecting and ordering parts a few years before the build started. One day I drove to go check the mail and the Jeep died. I thought it was ironic that it a postal Jeep chose the post office to die.
Anyway, some of the parts that I have orders long before the build started...
Trail Ready Front and Rear bumpers and nerf bars. I also have a Expedition Outfitters custom aluminum roof rack that is 30 pounds. Internal roll cage also...
The next stage I needed a engine, so I contacted Gregg Hekimian of Hekimian Racing Engines. He is a retired military defense specialist in engineering and does cryogenic work on engines also. We took in consideration everything about the Jeep. Tranny, axles, gears, tires, ect.
He custom built a Chevy 383 with 493 hp@ 5500 and 460 tq@ 3500, a real beast of a motor that purrs like a kitten. I wont bore you guys with specs...
I needed a tranny next so I bought a 700R4 core for $250 and took it to Top Jimmy in the valley. I gave Jimmy the build spec sheet for the engine and talked gears and tires too. Jimmy built me a top of the line custom application just for the postal that can handle everything I could throw at it.
Here are the next photos of the engine and tranny...I finally found a good use for that Chilton's manual ;) :rolleyes:
I love the help that the Chilton's manual is giving you Lost. :D This is one sweet build you have going. Are you using a carborated or an injection system for the "feeding"? Thanks for keeping us updated.
z
Been working on the house and just got some free time to work on the REAL project... ;)
Pulled the engine and tranny for protection then I set the body back on... This is the first rough mockup of everything...
Mounted the YJ fenders and the CJ grill and hood the got to mount the front bumper today and it ROCKS!!! Ok well I like it... :cool:
Next I get to level and square the body and double check the body mounts, pull the body off yet again to install the hard lines (gas & brakes), rear bumper, and nerf bars...Then set it on the frame again to start the internal cage, doors, racks, top and everything else to get it to a rolling stage...
So now for some photos...
Nice ! But that bumper looks very heavy. What axles will you eventually be running BTW ?
Its not quite as bad as it looks, and I will be running Currie HP D60's. I already have the rear, just waiting on the front.
Dean - great idea on the rear fender trimmming and bending. Mine are very rusted out, so I think I may look into doing something similar with what's left on mine.
What rear flares are you going to run? And does the trimming you did affect how you will mount them?
Thanks
-Mike W
On the axles... I got a good price from Currie and there was nothing local I could get built for it...(It had to be made for right hand steering as well)
Mike - I have 6" warn flairs for it, I still have to trim some of the flair because there is some of the raised lip that will be in the way. I will post photos of that when I get there...If I had to do it again I might get a piece of angle iron bent for the inside of the tub around the wheel-well (the same radius) I would cut the lip completely off so the side was flat and weld the angle iron on the inside, POR 15 and off you go... :D oops, forgot the flair :D
Okay, Ive seen so many choose ProRocks and RockCrushers...
