Quick and dirty Flatbed...more for function...not so much form
jpdeuce
Houston
Well, just to make BigWalton happy, I decided to build a flatbed this weekend. I figured it would be really nice in Hot Springs to have the functionality of the flatbed as well for tieing down a cooler and parts bin...so that was thrown into the mix of the decision as well (sorry Eric).
Anyway...I got a bunch of scrap wood from a neighborhood that is being built nearby (it had nails and stuff in it and was in the trash bin at each house) to try and cut down on the costs. Plus, I had some stuff laying around the garage that I could take back to the Depot anyway. So after getting the hardware I am using to tie it into the frame into the back...I'm about 4 or 5 bucks POSITIVE on the project so far :).
I'm doing this the real quick and dirty way...well as quick and dirty as I could think up. I'm laying 4 boards width ways on the Scrambler...one at the rounded cross member around the middle of the Jeep...one at the highest point on the frame above the fuel pump...and 2 on the back section of the frame. At this point I have them laying on there right now and secured to the frame.
So for today I need to run "joists" the length of this thing...2 or maybe 3...and then figure out what I am doing for the top. And then get it all level with the scrap wood.
Just thought I would tease you guys that are on here this weekend. I'll get some pics up today for sure. :p
OK, well I realized I only have my parents camera right now that has limited storage space...so it looks like I am going to upload some pics so that I can get the space on the camera.
Here's a couple of pics on where it's at from last night:
EDIT > Apparently this section of the board doesn't allow embedded images...so you will just have to click on the links :confused:
Overhead 1:
http://www.MyOnlineImages.com/Members/jpdeuce/images/Frame Supports 01.jpg
Overhead 2:
http://www.MyOnlineImages.com/Members/jpdeuce/images/Frame Supports 02.jpg
Here's how I tied the 3 back supports in to the frame...I will probably come back and put something between the metal and the frame...just wanted to get it working:
http://www.MyOnlineImages.com/Members/jpdeuce/images/Secure 01.jpg
Here's how I tied into the rounded crossmember:
http://www.MyOnlineImages.com/Members/jpdeuce/images/Secure 02.jpg
Hey, you gonna put a cage on it?
I've got some 4x4's to make it from, and there even pressure-treated :D
Just messin' with ya! :p
Get us some "after" pics when you can.
Alright...taking a break for lunch and thought I would show ya the progress. Had some things to think out and a trip to the Depot...but here it is. My biggest issue was trying not to make it sit up too high off the frame...for sturdiness...but also making sure each layer of wood is secure to the others so it doesn't get too wobbly.
I found just the thing in these brackets:
http://www.MyOnlineImages.com/Members/jpdeuce/images/Brackets.jpg
Here's how it sits now with the second layer complete:
http://www.MyOnlineImages.com/Members/jpdeuce/images/SecondLayer.jpg
Now I just need to run my side the side joists and I will be all set for the top. :D
Everything about this thing is hillbilly...so an all wood flatbed was just the topping it needed. I was tired of staring at frame rails anyway.
EDIT >> Besides, I feel more comfortable with wood anyway. No sparks flyin or helmet needed. Just a drill and a saw and create away :D
Finished!!!
Alright, well I am done with the first round of this thing...at least it makes it functional. I welcome ideas to improve upon this design and it's current state...would love to add some smart finishing touches. For instance...I already know I want to add some tie down loops before Hot Springs...stuff like that.
Anyway...on to the install...
Here's the top layer of support that the top is secured to. Pretty basic...just like a deck or something:
http://www.MyOnlineImages.com/Members/jpdeuce/images/TopSupport01.jpg
http://www.MyOnlineImages.com/Members/jpdeuce/images/TopSupport02.jpg
I got this piece from my brother...he got it from like the Art building at UT...apparently they were throwing out a bunch of old drafting tables and stuff, so he grabbed this top and was using it in his apartment. Well...when I moved him out for this summer just a little while ago I spied this top and figured it would be perfect for a wokr bench. Well...it just so happens we are doing some construction at my office and someone ordered an extra door for a closet and they were just going to throw this door out. And this isn't like an interior house door that's hollow...this thing is solid wood...100 pounds at least. So...that became my new work bench top and I found something to use this top for :D.
http://www.MyOnlineImages.com/Members/jpdeuce/images/TopMain01.jpg
http://www.MyOnlineImages.com/Members/jpdeuce/images/TopMain02.jpg
Also when I was out picking up scrap wood in that neighborhood, I happened to come across this huge pressure treated beam material that they use for real long runs on lofted ceilings. Just so happens I had a battery powered saw handy and I cut my 2 - 6 foot pieces off. Didn't know if I would use them but they turned out to be PERFECT for the sides. I cut an opening for the wheels well just in case. There's no way my suspension is that flexy...but who knows.
So, here's the finished setup (for now)
http://www.MyOnlineImages.com/Members/jpdeuce/images/TopDone02.jpg
http://www.MyOnlineImages.com/Members/jpdeuce/images/TopDone03.jpg
http://www.MyOnlineImages.com/Members/jpdeuce/images/TopDone01.jpg
I was thinking of adding some 1x around the sides just to sort of finish it off...or at least the back...I don't know...haven't decided yet. What do you guys think I should do? Is it fine as it is?
Lookin' good. I think some tie downs and some 1x to finish it off (hide your base and maybe give you a little lip) would look great.
Truck
It needs a small sofa back there :D ................
I always thought Elly-may was hot....
James,
I hope you fixed your rear dragging brake.....I'd hate for Hank to have to use his house fire puttin' out skills to work on your ride.... ;)
It's a creative solution to a problem....Good Job...
Actually check for my emergency issue needing to be resolved before Hot Springs post...I think I'll put it in the drive train section (hint...you hit the nail on the head)
Prettty cool idea.
No we only need to get Mules a Chain Saw, so he can help you in bobbing it.
Carl
CBRogers said:
Prettty cool idea.
Carl
HA...actually I "pre-emptively bobbed" it...I BUILT it stubby rather than messing with an overhang or anything. If someone bobbed it as it is now then I would be in serious trouble back there...wouldn't have a place to mount my gas tank. :eek:
You sure that beam was scrap? Sure looks like a couple of nice pieces of lumber! ;)
I love it! :D
I love it! :D
Glad you approve...action photos coming very soon of the flatbed (and your axles) putting in some work. Had a fun time on my first trip. I'm sure it will take a month to get everyone's story on here and everyone caught up. :rolleyes:
Anyway...the flatbed worked out great...cooler held fine. I actually bought some cheap door handles to use as tie spots :D ...figured it was appropriate with the wood :D
I'll update this once I get some trim on here and make her look a little more pretty.
