Scrambler FAQ topics (need input)
1x1_Speed_Craig
Simplify...
Greeneville
TN
The development of a comprehensive Scrambler FAQ was mentioned in another thread. Here's the "first cut" of topics/questions I came up with. I'm sure I'm missing a LOT, but I think it's a good starting point. Please reply to this thread with ideas, and I'll edit the original list accordingly.
Keep in mind that we want to keep this fairly Scrambler-specific, and can reference other Jeep tech sites for some of the answers to "general" Jeep questions.
BTW, here is the MTBR.com Single Speed (bicycle) FAQ that I wrote a few years ago, just to give everyone an idea as to how I structured the FAQ page/information. Note that I only update this page ~once per year, so some of the URLs may be invalid now (time to update it again).
Thanks,
Craig
Production Information
  • What are the production years/numbers for Scramblers?
  • What trim levels were available on Scramblers?
  • Are there any particulary unique (relatively speaking) Scramblers? (Yes Alaskan Postal Scrambler & Scrambler Overlander)
  • What are some of the Scrambler's "key" dimensions?
  • What stock driveline components (models) were Scrambler was equipped with?
  • Were V-8s ever offered in Scramblers?
Interior
  • Did Scrambler come from the factory with a rear seat?
  • How can I install additional seating? (1 rear seat, 2 rear seats, FJ-40 jump seats, etc.)
  • What vehicles make good donors for front seat swaps?
  • How do I install shoulder harness seat belts in my Scrambler (that is currently equipped with lap belts)?
  • What size speaker is used in the dash, and who makes a good replacement speaker?
  • How can I add shoulder harness seatbelts to an early ('81) Scrambler that only came equipped with lap belts?
  • How do I remove the dash on my Scrambler? Click for answer
Roll Bar(s)/Roll cage(s)
  • What supplemental roll cages are compatible with the factory 1/2 top?
  • Are there "family style" roll cages available for Scramblers?
  • How can I remove my rusty ("frozen") rollbar Torx bolts?
Body/Top
  • Is a Scrambler the same as a CJ-7 from the doors forward?
  • What are the main differences between a Scrambler and a CJ-7?
  • Where can I find steel repair panels for my Scrambler?
  • What types of replacement body tubs are available for Scramblers?
  • What does "bobbing" a Scrambler mean?
  • Can you install TJ flares on a Scrambler?
  • What type of body armor is available for Scramblers?
  • Where was the factory spare tire carrier mounted?
  • Did some Scramblers come equipped with wood (bed) side rails?
  • Can I install YJ front fenders on my Scrambler?
  • If I wanted a unique look on my Scrambler, are there other front clip options I could use? (YJ grill/hood, TJ grill/YJ hood, DJ grill, CJ-10 front clip)
  • What is the "Jeep Lean"?
  • Did all Scramblers come from the factory with 1/2 tops? (Yes, 1/2 hard & 1/2 soft were available, with exceptions {AK Postal & Overlander})
  • Are full tops (soft and/or hard) available for Scramblers?
  • How can I stop my hard top bolts from coming loose on the header strip of the half hardtop?
  • What bedliner and/or undercoating options should I consider for my Scrambler?
  • Can I use YJ Wrangler 1/2 hard doors on my Scrambler?
  • Will YJ Wrangler full hard doors fit on my Scrambler?
Frame/Chassis
  • What are some of the common trouble areas on Scrambler frames? (rust, stress cracks)
  • How can I clean out & rust-proof the inside of my Scramler frame?
  • Plating the frame (repair/reinforcement)
  • Who makes replacement Scrambler frames?
  • What is the Scrambler's wheelbase?
  • What size gas tanks are available for Scramblers? (15- and 20-gallon OEM & large-volume aftermarket gas tanks)
  • Is the fuel filler nozzle specific to the Scrambler?
  • My frame's body mounts are rusted; how can I repair/replace them?
Engine
  • My Scrambler's carburetor seems tempermental - is this normal?
  • What is the "Nutter Bypass"?
  • What options are there for replacement carburetors? (MC2100 & ?????)
  • What can an ignition upgrade (TFI and HEI) do for the performance of my Scrambler?
  • What are common engine swaps for Scramblers?
  • What is involved in a later-model 4.0L engine swap, and what should I look for with the donor vehicle? (Renix injection, OBDI HO motors, and ODBII motors)
  • What does "stroking" a 4.0L motor mean?
Transmission
  • What transmissions were available in Scramblers?
  • Were all Scrambler transmissions good transmissions? (mention SR-4 weakness)
  • What are some potential transmission swap options for my Scrambler?
Transfer Case
  • What transfer case does my Scramblers have?
  • Should I consider swapping in a different transfer case?
  • What is the proper way to engage 4WD (shif the transfer case)?
Axles
  • How strong are stock Scrambler axles?
  • How can I strengthen the AMC20 rear axle? (1-piece shafts & welded tubes)
  • Can I add a full-float kit to the AMC20 rear axle?
  • Are there stronger hubs available for the Dana 30 axle? (6-bolt upgrade)
  • What are good front axle swap candidates for my Scrambler?
  • What are good rear axle swap candidates for my Scrambler?
  • How do identify various axle models?
  • How can I determine my axle gear ratio?
  • What is a limited-slip differential, and was this a factory option?
  • What are lockers, and should I install them in my Scrambler?
Suspension/Tires
  • What's the largest tire size that I can fit on my Scrambler?
  • How do I do a spring-over axle (SOA) lift on my Scrambler?
  • What is a Shackle Reversal System (SRS), and what are the pros/cons of this setup?
Brakes
  • How do I convert from manual to power brakes?
  • Are there rear disc brake conversion kits available?
Steering
  • How can I fix the sloppy (scary) steering on my Scrambler?
  • Is there a way to "beef up" the existing steering system on my Scrambler?
  • How do I convert from manual to power steering?
  • What is hydraulic steering, and do I need it? (assist & fully hydro)
Scrambler "Trouble Spots"
  • What kind of problem areas should I look for when shopping for a Scrambler?
    - AMC20 rear axle (if powerful motor swapped in)
    - Holes in frame
    - Stress cracks in frame
    - Floorpan rust-through
General
  • What is the Scrambler Owners Association?
  • What is the "S.O.A. Great 8 Restoration Charity Project"?
  • Is it possible to build a "mail-order" (aftermarket) Scrambler?
  • What is the best way to insure my Scrambler is properly insured (e.g. - adequate coverage) with my car insurance company?
  • Is my Scrambler considered an "antique car"?
  • Why does Marine-OpLaw have so many Jeeps? ;)
  • Where can I find other Scrambler owners? (http://www.frappr.com/jeepcj8scrambler)
Buying/Selling
  • How much should I pay for a scrambler?
  • How much should I sell my scrambler for?
  • What trouble areas to look for/disclose when buying/selling a Scrambler?
Awesome !!!!!
Perfect ... Thank you Craig for stepping up on this. I know most of us as daily readers won't get the real benefit of this, but you don't know how much it will help with persons just coming to the site. I get frequent direct emails always asking 1-2 of these questions every week. So, this will be great to direct them right to this or have it on a prominent place.
Thanks for giving back craig.
Matt
Looks pretty comprehensive. Lots of info at your fingertips.
More specific questions can be found by searching, if needed.
Good job, Craig!
1x1_Speed_Craig[list said:
[*] Why does Marine-OpLaw have so many Jeeps? ;)
[/list]
:D :D :D
Very comprehensive Craig..good job..
Truck
AWESOME list :D Personally I would leave out sections like "Bobbing the Scrambler" :eek: I would hate to give a NewBee the wrong Idea ;)
Couple of thoughts:
Transfer case, and potential Swaps
Part common with the 7. Probably easier to say what parts are different.
Oh ya, common customizations (Spring over Axle, lifts, engine swaps, lockers, other types of ideas)
Good list!
HEY!!! I resemble that remark! (So..., do I get to provide the answer myself?
Truck said:
:D :D :D
Truck
If I may... It's really quite simple: He's SICK! :eek: SICK, I tell ya'!
SICK...,
SICK...,
SICK....
But I would note that motivating 'friends' like Truck can make recovery almost impossible! ;) (Thank God I'm blessed w/ Big'un Eric for some counter-balancing. :) )
Finally, and w/ all due respect to JC and you other 'hacks' :D , I agree w/ Stouttrout's observation... If, indeed, we are all about preserving the few surviving -8's, I don't think we oughta encourage (by even mentioning :U ) this "bobbing" heresy. :( Make 'em search for it.... ;)
Hey, this would be great. After this, I won't be bothering the hell out of Grantshire asking the same questions over and over (because I have the typical male lack of comprehension first time around).
When you mention posssible replacement/upgrade/swap parts, you might want to mention how to recognize the parts (such as the shape of differentials). That's something I have to get one on one schooling from Grantshire constantly.
Some thoughts:
What types (manufacturers) of full hard tops were there:
Shackle reversal or not:
Weber 32/36 vs. Weber 38/38 vs. Motorcraft 2100:
Bumper types (tubular vs. square tube):
Rock sliders vs. nerf bars:
Rhino line interior:
Undercoating:
Gauge troubles:
Wow! If you list the answers to all those questions, this forum will become obsolete! :D
On a more serious note - I'm certainly no lawyer, I'm not even very smart, but I would probably think twice about giving an official looking answer covering rollcages or spring over axle lifts.
List updated. Other well-established (comprehensive) tech sites will be referenced for certain topics. Nerf bars & rocker guards will be covered in the "body armor" section. Thanks for the input, guys...keep it coming.
Craig
Scrambler FAQ
Being a new Scrambler owner I think this is a great idea. I have many questions that are specific to the Scrambler and those manuals for "all Jeeps" don't seem to be much help. You can spend alot of time searching threads to find answers that are relative to your problem however may not explain it in a way a "Newbee" would understand. I appreciate this site and visit often. :)
Here a couple that are Scrambler unique:
* What are the best console options for stock seats?
* I want to mount an overhead CB, light console but no one makes one that fits my rollbar or mounts up to my hard 1/2 top.
* Who makes a good flush mount 3" speaker for mounting behind the flat dash panel?
* Running dual exhaust on a Scrambler. How do you do it? Part numbers, brands, etc. OR is it even necessary?
I'll try to think of more.
Not to pick on those last suggestions, but somethings are better if discussed in the forum. That way you get different opinions, and different suggestions. You may like one person's idea better than anothers. It's what works best for you. Some topics just won't have one clear cut answer. That's also what makes everyone's jeep unique. Just a thought.
OK...I'll start working on the FAQ content over my lunch hours. It'll be a "as time allows" deal, and I'm guessing it'll be 3-4 months in the making. I'll probably be posting for detailed info regarding some of the tech topics that I don't know much about.
Stay tuned. I'll work with Matt Donaghy to get this stuff posted as I get it developed.
RandyLL - Anyone can still search. The goal of the FAQ will be to answer most of the typical questions. As Matt said in an earlier post, he gets several questions each week about the same topics. Individual threads found through searches will provide people with more information, suggestions, research, etc.
Thanks,
Craig
