Electric fan install
jscherb
Elmira
NY
Just finished the install of my electric fan this morning. I used a Ford Contour dual fan - see below, it is a perfect fit for the stock CJ radiator, drops right into the frame.
I used the DC Control fan controller, varies the speed of the fan as necessary for cooling, soft starts the fan so no big current draw on startup.
The coolest thing to watch is the engine heating up at idle, when the temp gets to the threshold I've set the fan just starts ticking over and slowly builds up speed as necessary and then slows back down after the coolant in the radiator gets back to the threshold temp.
Because the fan only runs as fast as necessary, it is very quiet... no, it is eerie quiet - no more fan screaming as I row through the gears.
Seems to hold the temp very solid, after some real use test I'll let you know how its working out long term...
Jeff
attachment.php
attachment.php
what model did that come off of..?..I have never seen a contour with a dual fan...i love the way it fits
This fan can be found on a mid-nineties Ford Contour SVT with the higher performance engine option – either the 16 valve “Zetec” engine or the 24 valve 2.5l “Duratec” V-6.
Jeff
awsome..i will be looking into that..i got a lincoln fan and it puts out 5500 cfm...but it would not fit with my chevy v8...I would love to get rid of the stock fan
The specs I have show this as a 3400 CFM fan. FYI the "Taurus fan", Ford #8C607 two speed, is a 3800 CFM fan, also found in some Lincolns. I've seen all kinds of wild CFM numbers for that fan but I believe the 3800 number to be accurate. The Contour fan is only 400 CFM less than the "Taurus fan".
Jeff
Interesting. I'm running a Taurus fan in my Jeepster with a Dakota Digital controller on a Be Cool CJ radiator. Works and fits great, but it is noisy and does stick out a ways. I'll have to look into the Contour fan for my next swap. Thanks for the info!
Sweet fit Jeff, That looks like it was made for it....
Truck
Whipped up a little control panel for the fan today. Switch has three positions - normal (letting the DC Control unit decide how fast to run the fan), Always On (runs at 50% or more depending on cooling needs) and Always Off (you might use this for a water crossing). Top LED glows from green to yellow to red as fan speed increases so you always know how fast the fan is running. Bottom LED glows red in Always Off mode.
Wiring this up was pretty trivial given the functionality of the DC Control electronic fan controller.
Jeff
attachment.php
Controler
Do you have a part number for the dc motor controler?
Thanks
Don
The fan controller part # is FK-35. That's the kit including the wiring harness and misc. hardware. Also required was a # 1.5KS filter due to the low impedance of the Contour fans.
I also bought their indicator LED and built it into my control panel, I don't have the part number handy right now.
Jeff
BTW, I've been running this setup for a couple of weeks now, and I've had the fan speed indicator light operating for about a week. The weather here has been 30's-50's. I've used the Jeep mostly around town but also on the highway.
It is surprising how little the fan runs. The fan speed LED never glows full red, indicating the fan is never running at top speed. Most trips I make are around town, stop-and-go errands and the fan runs maybe 10% of the time, and the light only gets light red, indicating maybe 50%-70% fan speed for that 10% of the time it is running.
Temp is rock solid right where it is supposed to be.
Also from inside the cab you can't hear the fan running, even when it is at high speeds. Compare that to the stock 7-blade steel windmill!
What's cool about this is that the fan runs at the speed necessary to keep the water leaving the radiator at the right temp, and in this cold weather that means it doesn't have to run much at all. Contrast that to a controller that ties into the stock temp sender in the engine - the fan would be running much more because the water in the engine is hotter than the water in the radiator. So I would venture to say that this solution reduces temp cycling in addition to reducing the amount the fan runs, keeping temps much more consistent. Some people don't like the idea of the temp sensor in the radiator fins and opt for the controllers that tie into the stock temp sensor, but in my opinion so far this is a better solution.
I'm very happy with this mod and the DC Control electronics. We'll have to see how it does in the heat of the summer, I'm sure all I'll see is the fan running a higher percentage of the time.
Oh also this project is the subject of an upcoming article in jRations; I submitted the finished article, photos and drawings to the magazine the other day at their request. Not sure when it will run in the magazine yet.
Jeff
1x1_Speed_Craig said:
Jeff - Everything you have done to your Scrambler has such great execution. Nice work! :cool:
Craig
Ah shucks, Craig, thanks :-)
This is all just the warmup for my TJ/Willys pickup project, I'm hoping I'll be skilled enough to pull that one off...
Jeff,
how much clearance do you have between the fan and water pump?
Any chance you can get me a photo of how much clearance you have?
Thanks
RJCJ-8 said:
Jeff,
Thanks
There's about 1/2" between the end of the water pump pulley bolts and some reinforcing webs on the plastic fan housing.
I did not cut the water pump pulley studs shorter, they now stick out at least 1/2" beyond the nuts, so if you wanted more clearance you could shorten those bolts and get maybe 1" clearance from the pulley nuts to the fan housing.
If you wanted even more clearance than that you could trim the reinforcing webs on the fan housing and get up to perhaps 2" clearance.
But the engine isn't going to move even 1/2" forward, so the clearance I've got is fine.
Jeff
EDIT: Refer to the first photo in this thread, the Contour fan is a dual fan, which is nice because the engine water pump pulley sits between the two electric fans, which allows easy clearance.
