jscherb
- Elmira
- NY
Just finished the install of my electric fan this morning. I used a Ford Contour dual fan - see below, it is a perfect fit for the stock CJ radiator, drops right into the frame.
I used the DC Control fan controller, varies the speed of the fan as necessary for cooling, soft starts the fan so no big current draw on startup.
The coolest thing to watch is the engine heating up at idle, when the temp gets to the threshold I've set the fan just starts ticking over and slowly builds up speed as necessary and then slows back down after the coolant in the radiator gets back to the threshold temp.
Because the fan only runs as fast as necessary, it is very quiet... no, it is eerie quiet - no more fan screaming as I row through the gears.
Seems to hold the temp very solid, after some real use test I'll let you know how its working out long term...
Jeff
Jeff
