update
I probably should start another thread for this build but I think I have posted too
much already to go back and move stuff. O-well. Anyhow I got the frame back from
the sand blaster.
Finally a guy that knows how to do his job. The frame turned out great. Before I
primed the frame I did use some metal ready stuff by DuPont. I normally would not
have used this metal ready stuff. I normally would have just used acetone let it
dry and sprayed it with primer. My first thought was that putting water on a bare
or sand blaster piece of metal would be bad. And I was right.
Let me start with I had never used metal ready before.
None of my friends have ever used metal ready before.
But for some reason I wanted to use metal ready on this project.
The guy at the paint store told me that all I had to do is spray this stuff on with
a spray bottle, rinse it off with a hose (water), and let it air dry. And the directions
he printed off the internet stated to do the same thing.
*note (the guy at
the store had to print off directions off the internet because the bottle did not have
a label). So I go home and do this. And as the frame is air drying it starts to surface
rust. So I re-read the directions and repeat what I had done before. And I came out
with the same outcome. So then I call the store and just so happens I get a hold of
the same guy who I had talk to the day before. He then tells me that I need this other
stuff and that the metal ready is a two stage process. At this point I'm like ***! So I
hang up the phone with him and get on the internet. I go to DuPont’s web page and find
out that: Yes this is a two stage process. But only if you’re working with aluminum. And
also that the guy only printed out 1page of 3page directions. And I found out that you
do not let the metal ready air dry when only doing the one step. That you keep the frame
wet with the product and water until you dry it off with a towel. So after messing around
for a few hours I finally got the frame metal ready, let it dry in the sun, and primed it! And
it looks great.
