1985 cj8 build
Well, at least you got the satisfaction of knowing you did things right, and that the cops know of another disreputable businessman. Believe it or not, that does matter.
So, what brackets are you still missing? I don't see one of the frame to sway bar brackets in the picture....
well your dead on!
I'm Missing:
1-swaybar to frame bracket.
1-bump stop plate.
I have another set on an old frame I have.
I guess its just the principle that the parts were mine!
I'm glad that it was not some really hard to find or expensive part!
but I will make do.
On a highlight I did recieve my genright gastank skid plate today.
I'm still trying to decide what I'm going to do with this jeep as far as:
*motor
*tranny
*body
*roll cage
*tires....
I think I'm going to convert the rear dana 44 to disc brakes and but a high steer kit on the front axle.
update
I probably should start another thread for this build but I think I have posted too
much already to go back and move stuff. O-well. Anyhow I got the frame back from
the sand blaster.
Finally a guy that knows how to do his job. The frame turned out great. Before I
primed the frame I did use some metal ready stuff by DuPont. I normally would not
have used this metal ready stuff. I normally would have just used acetone let it
dry and sprayed it with primer. My first thought was that putting water on a bare
or sand blaster piece of metal would be bad. And I was right.
Let me start with I had never used metal ready before.
None of my friends have ever used metal ready before.
But for some reason I wanted to use metal ready on this project.
The guy at the paint store told me that all I had to do is spray this stuff on with
a spray bottle, rinse it off with a hose (water), and let it air dry. And the directions
he printed off the internet stated to do the same thing. *note (the guy at
the store had to print off directions off the internet because the bottle did not have
a label). So I go home and do this. And as the frame is air drying it starts to surface
rust. So I re-read the directions and repeat what I had done before. And I came out
with the same outcome. So then I call the store and just so happens I get a hold of
the same guy who I had talk to the day before. He then tells me that I need this other
stuff and that the metal ready is a two stage process. At this point I'm like ***! So I
hang up the phone with him and get on the internet. I go to DuPont’s web page and find
out that: Yes this is a two stage process. But only if you’re working with aluminum. And
also that the guy only printed out 1page of 3page directions. And I found out that you
do not let the metal ready air dry when only doing the one step. That you keep the frame
wet with the product and water until you dry it off with a towel. So after messing around
for a few hours I finally got the frame metal ready, let it dry in the sun, and primed it! And
it looks great.
Wholly crap!!! I just read this entire thread and I've come up with one thought...you have had the worst luck with this frame. Looks good now!!!
I'm in the same place as you with my build, well slightly behind actually. I've welded on Chief Wahos frame plates and rear cross member, and I'm ready to bring it to the sandblaster. I was quoted, on the phone, between $200-$300 to sandblast the frame (depending on condition)and another $150 to spray it with a sealer/primer.
This guy is local to me with a good reputation. I'll keep you updated.
Its actually funny. because If I'm working on a jeep to sell or for another person I run into no problems(99.9%). but if it has anthing to do with a jeep for me. forget about it. I wish I would have found the guy who actually sandblasted my frame the first time around. He only charged me $150.00. and I prepped/primed for another $40.00. well that's how stuff goes sometimes. I should have a rolling chasis by this friday. I order shackels, bushings, jks cj-yj conversion spring hangers. and I have been wire wheeling and sanding my axles getting ready for primer. so I'll keep the post/pic's coming. good luck with your build.
7jeeps7kings
cj8 update
with all the rain delays and call offs I just might have a complete rolling
chasis before august? I finally got the rear axle clean and ready to go.
I have it coated with wd-40 so it won't rust.
So since I was done with the rear axle I figured I would start on the front axle.
so I degreased, wire wheeled, and sand the front axle. I actually got everything
done with the front axle tonight only it got to dark to take pic's. but heres one
of the front axle hanging around on a cherry picker.
The cherry picker works great for all kinds of stuff. and while I was working on
the jeep the UPS guy showed up with the new jks rockslider cj-yj conversion
spring hangers. Yeah!
So by friday I should have a rolling chasis.
Well I did not get the cj8 project into a rolling
chasis this past friday. but It will be done
by this saturday. I got some stuff done. I
bought new bolts for the spring hanger and
springs. I mounted the jks spring hangers.
so all I have to do is mount the springs, shackles,
and axles.
here's a pic of my parts, I'll have ones of the rolling chasis this saturday.
As promised a rolling chasis
well the cj8 is rolling around on it's own four wheels.
I found out the bushings I had ordered were not the
right ones. the YJ bushing kit was made for oem YJ
springs and shackles. Which is different from aftermarket YJ
procomp springs. the oem YJ spring eyes that matches up with the
shackle are 1.25". The procomp YJ spring eye that matches up with
the shackle are 1.50". So I will have to send them back and order
new. also if you notice in the pic's the shackles don't look right
that's because they have the wrong size bushing and they are not
tight. here's some pic's of the progress:
As mentioned above: I have been really busy.
I have sold the engine out of the cj8(258)
I have a deal pending with the tranny out of the cj8(TF999).
And I crated it for shipping.
And I went and got the frame back from Shopteach(screen name on jeepsunlimited.com). And it looks great.he replaced: my rear crossmember, fixed three other body mounts, weld my new dynatrac shock mounts, weld on new sway bar mounts on the axle, and also removed the old spring perches and replaced/welded new spring perches front/rear that I got from m.o.r.e.(the spring perches with the three holes in them so you can move the axle). I can't say enough about what a great job he does.
And I have been looking all over the internet for a ls1,lq4 motor for my cj8 build. It's time to go gm(with this one. And maybe the other). I plan on pulling everything apart on the cj8 frame and painting it this next coming week. I'm still trying to decided if I'm going to fix the cj8 body I have or buy a new fiberglass one from 4wd? O and I have been driving the big yellow '77 all over. I love summer. I just wish they were a little more sunny and warm in Ohio.
7jeeps7kings
ps. I thought I had seen someone on this forum that either made or bought bolt on motor mounts for a ls1/6.0L/gen III or gen IV motor. I've looked for that thread and can not find it!
Help!LOL
I used M.O.R.E. SBC bolt on mounts, and then made a simple adapter plate for the GenIII engine.
What brand is the u-bolts & hardware? And where did you get them? I like and want to get the same.
Don
I had 3 choices on the flex fuel sensor.
First was to eliminate it, change the injectors to non flex-fuel injectors, and have the computer reprogrammed. A lot of extra work and I like the bigger flex fuel injectors.
Second was to purchase a "sensor eliminator" which gives a false signal calibrated for 10% or whatever you tell them. Stands the chance of running too lean if the % is incorrect for the fuel you're using. The company even states the possibility of better mileage due to a different fuel mixture, but at what risk?
Third choice- leave it in. That's what I did, no other modifications, now the computer will tune optimally for whatever % of ethanol there is in the fuel.
Seems flex-fuel engines are easier to come by and mine was cheaper, too.
sounds like you made the right choice!
For anyone looking to move to Ohio
For anyone lookig to move to Ohio? Stay away. It sucks. i have been non-stop painting my house for the past three weeks!
I can't catch a break. I'll get one day of paint in and then it will rain! then I have to wait 24-48 hours to let the house dry
before I can paint again. Ohio----yuk!
anyhow the jeep has been on the back burner big time. Although I did get a chance to go out and buy and look at some parts.
I did end up buying a used set of yj half doors for the scrambler for a great deal. and I also made it out to a salvage yard in
columbia station Ohio to check out some lq4 6.0L/ls1 6.0l engines. The company is called Cleveland Pick-a-part. the Owner Big Rick
showed me around. And man did I want to buy everything in sight! This company has almost every high performance fuel injected
motor that came factory in all kinds of new muscle performace cars in the past 5-10 years( viper motors, gto motors, vette motors...).
It looks like I have to save a little more money.
I also have been searching on the net about what tranny to go with. I talked with a guy at advanced adapters. I told him I was looking
to run the 4l80e tranny behind the lq4 6.0l engine and he told me that I should look for a 2wd setup. I have to do a little more research.
I have found a couple of different articles on the 4l80e 2wd and 4wd tranny's. I think they say that the 2wd tranny is the better one to go
with since it does not have a speed sensor in the tailshaft? anyhow I'll update when I find out. if anyone has info your more then welcome to
add comments.
7jeeps7kings
also The I sold the tranny out of the scrambler. if anyone is looking to ship anything freight I found a company online called uship.com. they have great rates.
anyhow.
Tomorrow is going to be an exciting day for the wifes cj8.
I'll post more tomorrow. but I just made a great purchase.
stay tuned,
7jeeps7kings
