I accomodated 35" tires by installing the RE 4.5" CJ lift, JKS Slickrock YJ width conversion shackle hangers, M.O.R.E 5/8" lift YJ front shackles, and a M.O.R.E 1" body lift.
When I called RE about their 4.5" springs, I was told that the CJ and YJ spring leaves were the same, but that the CJ springs had more arch to them making the eye-to-eye length shorter. They said that the YJ springs were just flatter and would provide a little less lift. So I went with a 4.5" CJ kit.
Not wanting to use the RE stepped down conversion shackles, I ordered up a set of JKS Slickrock shackle hangers, PN 9851. These are desgined to mount the shackle 1" forward from the OEM spring hanger position to work with presumably longer YJ springs. Not only did I not need that extra length, but moving the shackle hanger forward caused it to interfere with my front bumper mount. So I slightly modified the shackle hangers to allow them to mount close to the OEM location.
Using a drill press at work I drilled a shallow hole just deep enough for the frame crossmember rivet to fit into:
Then I found appropriated sized bushings at a local hardware store and inserted them into the holes originally intended for the frame crossmember rivets:
On the driver's side, the shackle hanger slipped right under the M.O.R.E. heavy duty steering box mount:
On the passenger side, I used some flat stock to make essentially a large washer to completely cover the hole with the bushing in it:
How it all turned out in the end:
