Suspension Choices
John n thats a really good point,and a lot of work.If the YJ spring is 1 inch longer in the rear what if you just put the YJ springs in backwards?that way the longer end would be if front of the axle and the you would not have to move every thing. I dont know if you could mount the spring backwards.Is there a front and rear on a spring with the same distance from center pin to spring end?
With CJ springs, the main eye is much larger than the shackle eye end of the spring. Unless you do a shackle reversal, you can't turn then around.
Binding
John N, when you went to the RE did you have the 4.5 lift and did you use the CJ springs in the front? Also, are you using a drop pitman arm or straight one?
I've got a few photo's of my front end set up and it is really hard to tell how far back the tie rod is from the pitman arm\draglink connection point. I can see now that if you don't have plenty of clearance then binding will occur when compressed. Your solution with moving the steering box forward and shortening the pitman arm must have been a pain but it does make a lot of sense.
When I get home I'll have to check to see how much clearance I have there. Sounds like the best solution may be to use the RE CJ springs with the RE conversion shackles or build\buy a 2.5" shackle hangar that is not longer than the stock CJ shackle hangar.
I used their 4.5" springs that come with their CJ kit. Mine have several years on them. There's no way to know if their springs are even made by the same company/sub-contractor now. Mine have sagged enough so that I'm looking at replacing them, possibily.
I hate drop pitman arms, they kill your turning radius. I have probably 10 different arms in my garage that I've experimented with. My current set-up, with high steer, uses an Astro van arm. It's short, flat and very stout; it had to be reamed to the larger drag link end size that I use. If you look, you can still see that I have some contact between the drag link end and the tie rod.
John- that's with the RE4.5 kit? I have a lot more clearance, but then again mine haven't sagged. I didn't move my box forward, so on compression my arm ends up behind the tie rod. But it clears- so far. I am considering flipping the tie rod onto the top of the Waggy arm, will give me another inch. Or, get a pair of those arms that put the tie rod behind the axle.
The tie rod is already on top with the Waggy knuckles, no flip needed. My 33's only measure 32" (if that). Those are RE 4.5" springs (1" body lift , too). I wan to run 35's, but there's no way right now.
John- I was talking about flipping the tie rod to the top of the Waggy Pitman arm. I'll have to see if it needs it first.
John
Where did you get your astro van arm? I've called several junkyards and they only want to sell the whole box/arm assembly.
I swapped in a D44 front and would like a flat pitman arm.
Thanks
Brian
John
Thanks
Brian
I got it a 'U-Pull-It' local place. I don't go very often. I know Ted Wendel goes fairly often, PM him, maybe he'll pull you one.
I accomodated 35" tires by installing the RE 4.5" CJ lift, JKS Slickrock YJ width conversion shackle hangers, M.O.R.E 5/8" lift YJ front shackles, and a M.O.R.E 1" body lift.
When I called RE about their 4.5" springs, I was told that the CJ and YJ spring leaves were the same, but that the CJ springs had more arch to them making the eye-to-eye length shorter. They said that the YJ springs were just flatter and would provide a little less lift. So I went with a 4.5" CJ kit.
Not wanting to use the RE stepped down conversion shackles, I ordered up a set of JKS Slickrock shackle hangers, PN 9851. These are desgined to mount the shackle 1" forward from the OEM spring hanger position to work with presumably longer YJ springs. Not only did I not need that extra length, but moving the shackle hanger forward caused it to interfere with my front bumper mount. So I slightly modified the shackle hangers to allow them to mount close to the OEM location.
Using a drill press at work I drilled a shallow hole just deep enough for the frame crossmember rivet to fit into:
Then I found appropriated sized bushings at a local hardware store and inserted them into the holes originally intended for the frame crossmember rivets:
On the driver's side, the shackle hanger slipped right under the M.O.R.E. heavy duty steering box mount:
On the passenger side, I used some flat stock to make essentially a large washer to completely cover the hole with the bushing in it:
How it all turned out in the end:
Great write-up
Boomer, it sounds like you have alreay been down the path that I may travel. You made it sounds pretty easy and have used the exact same parts that I have been researching. I was still undecided on the YJ or CJ springs but you bring out some good points and benfits of using the CJ springs.
Can you answer a couple of questions for me?
1. If you put your JKS shackle hangars in the location that they were supposed to go and modified your front bumper do you think the CJ springs would still work or would you recommend doing what you did and moving the shackle hangars back to the original position?
2. The 5\8" MORE YJ lift shackles are straight or did you use the boomerang version?
I cannot view your pictures on this government computer but if you can send me an email I can view them that way. I'll PM you my email address.
Thanks for taking the time to explain your process.
karl
I know the original post indicated that he was choosing between the three suspension options. But was just wondering if doing a flat fender and opening up the rear a bit may be an option.
I am really digging the low center of gravity designs some people have been using recently to run bigger tires and being more stable.
I'll pass along my set up and impressions
I'm running Alcans on my Jeep with the MORE reverse shackle kit. The springs are supposed to be 5" lift with an exptra 6" in length behind the center pin only. They do not have the orbit eye, wasn't available when I got the springs. In addition I had the front spring pin moved forward by 1", that was not necessary and I need to pul them and move the center pin back that inch. They are damped with Bilstein 5100s all around although I may go to adjustable Ranchos next time.
The are very comfortable on the street, a little soft even with the Bilsteins. There is a fair amount of nose dip under braking but not objectionable to me.
Off pavement they are superb, very supple and so far, no sag.
A friend has rear Alcans with the orbit eyes on his XJ, replacing a set of well used Nationals. He is very satisfied although his eyes make noise as they flex and that bothers him
My oldest daughter has Alcans on her Scout 800, there were no other options at the time and the springs made a world of difference in the vehicle, on road and off it is a new vehicle and infinitly more comfortable to drive. It has el cheapo pro comp shocks
suffice it to say that I really like the Alcans and they were super easy to work with in getting them built. I won't go anywhere else for leaf springs anymore if I ever need a set for anything
Low CoG:
Unsure of the lift but they look like 2.5"
forum
The springs I think are shagged as the front shackles are pointing almost straight down (I think it may even be an add a leaf system.
35's fit between the flares, though the passenger rear is catching as i think possibly the pin is snapped and is letting the axle move back. The drivers side is fine.
Ultimately, I'm going to go for a 2.5" kit (RE YJ2.5 extreme) with possibly a 1" body lift, or la 4.5" yj Extreme kit and trim some metal back.
I haven't flexed it as it is yet, but it's catching on the passenger rear. The passenger front catches at full left lock on the spring, but clears full right lock.
Companies like Alcan and National don't really exist over here. We can get custom springs made, but it's HUGELY expensive.
For comparison, My shop sells the RE 2.5 extreme YJ kit for 2,629 AUD. The 4.5" extreme is 2740AUD. Still not cheap in comparison to you guys in the States!
