Be safe!!
WOW!
I always thought I could bathe in all that stuff, since I don't do it every day. Sure, if you are a mechanic by trade you have have to be a little more careful, but I am just a weekend shade tree putzer arounder. I guess I better start paying attention.:eek:
I really need to watch that because I usually spray aluminum parts before welding them if it's a repair. I guess I've been lucky. Note to self:
I've has a few minor "incidents" like that. The worst was using a kerosene heater, and cleaning with brake cleaner, while another friend was spray painting. We felt dizzy after a while...opened the doors and wow...what a difference. Clean air, and not a moment too soon.
Did you know that R12 refrigerant also becomes phosgene gas if it runs through an engine?
I haven't had a good sense of smell for at least 5 years now, I'm pretty sure the junk I've breathed in is the cause.
I also now use nitrile gloves when I clean with brake or carb cleaner, or when I paint.
Great points Randy, I, too, suffer olfactory burnout after years of abusing the nose. I worked at an experiment facility that used sulfated howitzer propellant, the solvents used to clean mixed with the burnt sufated powder were very hard on teh smeller. When in the sevice we had a waste holding tank leak into a JP5 tank, that's a combination you cannot escape! sewage and jet fuel.
The heater, paint and brake cleaner must have been quite a cocktail, did you have the severe headaches afterward? I've cut corners and welded galvanized parts and suffered the zinc fumes for days, I can imagne the organic vapors from that mix, thank fully you were able to open a door and circulate fresh air before it became debilitating.
Sadly alot of the things we do also affect the nervous system, I have issues now with my hands and the ability to grip things linked no doubt to a variety of chemical exposures when i was young and invincible.....
Yeah, it was like the worst hangover ever, X10...
I have neuro issues too, mostly related to collapsed discs in my neck and moderate/severe carpal tunnel... but I do know that after a marathon welding session, or painting for that matter, the "tinglies" in my hands and loss of feeling in my fingers is worse for several days. Brake cleaner fumes seem to get the tingling in the hands going too...
I need to get this Scrambler finished before I can't drive it anymore!:eek:
Yeah, I am right there with you brother, if I had only known I would live THIS long I would have been more careful, sheesh!
If only the darn thing would get finished! Or rather, if only there were an end point so it could
