Charlie's cummins diesel transplant thread
Fellas,
I need radiator advice. I need to replace the rad in the Jeep to the best stock configuration model I can find. I have been told aluminum radiators are the best. Does anyone have experience with these and can they recommend the best brand? I am looking for the highest volume radiator that I can find that will fit in the stock loction.
Thanks-Charlie
Nobody knows anything about aluminum radiators?
We made some excellent headway over the past two days including the removal of the V8.
forum
Ready to drop into your CJ, completely wired to plug into a CJ's fuze block:D
forum
Removed the oil pan, which oddly enough was oriented as a front sump from the factory but has a rear sump part number (per the Cummins part parts manual there are three options, front, rear and mid)
forum
With a different suction tube we were able to re-orient the pan and reinstall with a Cummins gasket.
forum
forum
Finished it off with the Dodge Cummins flywheel housing. Thanks Doug!!!!!!!!!
forum
Everything is going to get steam cleaned and painted Cummins beige when it's assembled. It's a bit of an eyesore now!
forum
forum
forum
forum
forum
forum
Looks good Charlie, glad I could help!!
Got nothing for you on the aluminum radiators, sorry...
I can say :thumbsup: for the nice progress though!
The grand plan with the 6.2 diesel swap is to include an alum rad. I knew I was not going to have the capacity in the jeep of the rad that goes stock with the engine (full size chevy truck) so I figured anything to keep temps down. Also planning on an electric fan. I just picked up a BeCool unit second hand for $125. It needs some mounting brackets to mount into the grill but should work fine. I've looked at plenty and you are going to spend at least $250 for the cheapest ones I could find. They go up to $800. Other then the above I don't have any direct experience yet the alum rads.
Truck
Truck,
Thanks for the help. From what I have figured out through researching the subject, a 24"x20" standard copper three core radiator will cool a 4bt without equiping the vehicle with a fan. Most trucks that have the 4bt were the old bread trucks that were actually setup for a v8 gasser, so they have a large radiator which tends to be overkill (think cold all winter). I spoke with reps for two different brands (Novak and one other) that have what look to be good quality replacements in the $400 range. I will probably end up going with an al. rad made to be a stock replacement for the I6, but get it set up with 1 1/2" holes rather than the 1 1/4" that I think are standard. I should be able to re-use my flexlite electric fan setup that way. It should supply plenty of cooling capacity, if it's too cold in the winter, I'll get one of those winter fronts.
Guys,
Again I'm turning to the wealth of knowledge you all have for some advice.
I have heard of a paint-on/roll-on liquid sound deadening material for automotive use and wondered if any of you have any experience with this stuff. It needs to be water proof, or at least all weather.
I will do a search on my own, but figured I could start here. I am going to try and coat my firewall with something along these lines to mitigate the noise the 4BT will invariably produce. I would like to get something on order so I can put it on next week.
Thanks, Charlie
Take a look at this stuff. It's what I think I'm going to use when I get to that point. It's spray on, don't know if it can be rolled. They have two types,, sound deadening and insulating - if you want both, thay tell you which needs to go on first. It's not cheap either, but it's supposed to be good - I don't have any personal experience with it.
http://www.lizardskin.com/index.php
I bought front and rear frame plates for the Jeep from Mr. Adams to "beef up" the frame. I thought the very torquie diesel would need front plates to help the twisting, then decided to pull the tub to paint everything and thought, "mine as well do the back while I'm at it." I had a discussion with Rudy (Racin') about plating the frame. He was a bummed to hear that I was going to plate a perfectly good frame and for good reason. He raised an excellent point regarding the value of an original, unmolested frame Vs. a plated one. I gave it a lot of thought and decided to put the plates on, even though it is probably overkill. My decision was based on the notion that stronger is better for tough wheeling and I doubt I will ever sell this Jeep. If I did decide to sell it, it would be as an expedition Jeep rather than an original "stocker" so a buyer wouldn't care. I am making every effort to do a great job installing the plates, when its done it should be hard to tell they are there without scrutiny from a trained eye. I am going to chassis saver everything and fill the gaps between the stitch welds with urethane sealant, then chassis saver everything again leaving no obvious valleys.
Rebuilt fuel pump installed
The new Dodge/Cummins flywheel/housing/clutch/bellhousing assembly is huge, far larger than the Ford t-19 setup in the bread truck
forum
Front cover re-installed with a new seal between the crank and cover
forum
Tomorrow will hopefully yield a painted (chassis saver) frame and maybe a motor/trans/t-case dropped in to mock up the motor mounts
Looks great.
Not sure I get the issue with plating the frame, you're putting a diesel in it...right? Not like it's unmolested anymore :shrug:
Looks great.
I think the thought was even though the driveline was going to change, it could easily be returned to stock in the future without signs of alteration. Now, with a modded frame, that won't be possible. The frame was mint too, not a bit of heavy rust inside the tubes. I'm excited though, because now it will get a few coats of the best rust inhibitor I've ever used. I should be able to drive the ole' girl in the salt and snow without worrying about it.
I guess I'm saying who's going to buy a diesel Scrambler and then want to try to go back to stock? I'm assuming there's no chance that you'd ever do it if you're going through all this trouble. There's so many people on here who would consider this a dream build... I can't imagine it ever going back.
Overall, I think you're right on. Do what you want with it and don't worry about the value of the thing. :thumbsup:
Making progress. The oil pan is a little closer to the front driveshaft than I would like, but I should be able to lift the motor. Without the tub on, it's difficult to tell how high I can go. I spoke to a guy in KS the other day that did this very same swap who was going to send me some pictures.
This sucker looks a lot bigger inh the Jeep than on the stand!
Doug,
I'm not sure why they aren't working. You can always go to my picassa link on the first page; all the pictures on this thread are there and then some. Hopefully the front motor mounts get done tomorrow.
A new radiator is on the way. I opted not to go with aluminum because everyone I spoke with said a copper four cylinder cj radiator is enough. I took my old 6 cylinder radiator to the radiator shop to have it tested and to have the lower port moved from the bottom left to the bottom right. They said it had already been repaired and weren't confident it would hold up. They were willing to give me a 30 day warranty, but for $325 they were willing to sell me a new one and move the port where I need it and make it 1 3/4" from 1 1/2". This should eliminate the need to do any funky coolant hose plumbing. I ordered two gallons of quiet car sound deadening paint to do the firewall and underside of the tub, but unfortunately I won't have it till the end of the week.
We're going to change the oil filter housing to a standard Dodge Cummins style so the filter will be vertically mounted. This should make oil changes cleaner. Once the gaskets arrive, I already have the housing which was purchased off ebay, it will be installed. Additionally, we're putting a new water pump on since the pulley (non-removable) was so rusted I didn't think a belt would last.
Thanks for keeping up with my build-Charlie
Hi Charley great build-up! :thumbsup: I am in the middle of the 'parts-gathering' phase for my 4bt/CJ8 project & just ran across your build thread. I have my engine, adapter, tranny, tcase but I'll be swapping axles before I get started. Still a Lot of details to work out but it looks like you will likely tackle many of them before me = THANKS! :D I'll be starting my own build thread when I dive into my axle upgrades, hopefully within a month or so.
Were you able to get some pics of your engine mounts (or did the pics become red X's?) Do they use the solid rubber mount or the round hydr. type?
Also what did you come up with for your harmonic balancer?
Thanks,
Tim aka Oilburner
Thanks for the compliments.
Before you get carried away with axles, make sure they are going to fit with the motor. I am having problems with clearance between my oil pan and the front yoke on my stock AMC 30. I wanted to put in a high pinion D44 from Currie, but know I won't be able to without an absurd amount of lift I'm running 4" + 1" body at this point). I'll probably go with a low pinion Ford 9" as I think the third member is shorter and would afford me more room to work.
You may not have any problems if you are going to use a stock type jeep trans and ford adapter setup. The NV4500 with the Dana 300 adapter is very long compared to something like a T18, etc. so this could be part of my problem. This all of course is assuming you will be off-roading it. If not, disregard my ramblings.
As for motor mounts, I am making my own out of parts salvaged from the bread truck. It used the round liquid filled mounts. I bought an engine mount kit from Jeff Daniels Jeeps for the 4BT, but am not going to end up using it. Regarding the harmonic balancer, I won't be using one. My Cummins mechanic talked to an engineer at Cummins who suggested we not use one. He said it would actually take away from the HP of the engine. I wasn't going to argue as I'm not an engineer and that advice is going to save me $500.
-Charlie
