Charlie's cummins diesel transplant thread
Before you get carried away with axles, make sure they are going to fit with the motor. I am having problems with clearance between my oil pan and the front yoke on my stock AMC 30. I wanted to put in a high pinion D44 from Currie, but know I won't be able to without an absurd amount of lift I'm running 4" + 1" body at this point).
You may not have any problems if you are going to use a stock type jeep trans and ford adapter setup. The NV4500 with the Dana 300 adapter is very long compared to something like a T18, etc. so this could be part of my problem. This all of course is assuming you will be off-roading it. If not, disregard my ramblings.
-Charlie
Actually, I have a Ford HP Dana 44 I'm planing to use, to move the driveshaft to the driver's side & avoid the exhaust. I've seen several other 4btJeeps w/ this axle, not sure what you mean by needing a crazy amount of lift? I'll be narrowing this axle myself & could outboard my springs to move the chunk farther if needed. I'll be using more Ford stuff, an M5R2 5 speed + a Bronco Dana20 t-case.
More help needed!
I need to try and eliminate the stock style Jeep MC from my firewall, will adding a hydroboost setup allow me to do this? Can anyone direct me to a definitive thread on the forum for installing hydroboost?
In order to run the stock Dodge Cummins style clutch MC, I would need to shim the brake MC off the firewall at least 2+", hence my desire to go with a brake system that didn't have the large round portion. I plan on drawing my brake vaccum from the power stearing pump on the 4BT's accessory gear drive, which was how it was done in the bread truck, I havn't looked to see if the bread trucks brake MC would be something I could use. I just keep hearing about how much better hydroboost would be for 35"-37" tires, so here I am.
I spoke with my local mechanic who said something like the it works in conjunction with my stearing gear box (which is power, made by TRW), but the jury is sort of out there.
Any help will really be appreciated.
Thanks, Charlie
Just my Thought...
Hey Charlie...looks good!
I was just catching up w/your thread, as I haven't been on the site in a while...
Ref: the oilpan clearance...I am doing a SOA-going to a full width D44 and putting the springs
outboard. I have my body on the frame and discovered there would be a clearnce issue w/the exaust(unless I did a 90*/90* elbow-too tight for flow) so I am going to use a 2" body lift-(3"-45*/45* elbow). In order to leave room for the exhaust(3") at the firewall and for the exhaust pipe to also have room to clear the frame and T-case. I plan on running 35s at first.
BTW- what ya do w/ those engine mounts you bought? How much were they?
Keep on truckin on it!
Brian
One More Thought...OR TWO...
I forgot about the radiator.
I have the same problem concerning the air/air cooler and for me an a/c condensor to the front of the rad. Not much room up there for all that.
I have seen yj's w/the rad. mounted towards the engine-not in the rad. opening...I am starting off w/my 3-core rad. out of my '65 mustang to start off with and get an idea of how easy or difficult it is to keep cool down here in 100+* days. It also mounts to the inside like the yj. I'll just do some adapting to get it running and go from there.
I had the 151 and 4spd(already have the clutch MC) originally; so I am thinking about trying to adapt it to use w/the Dodge clutch set-up. Pretty much one custom connection to mate the old w/the new Dodge slave cyl.
After reading some about it on the swaps site..it comes down to stroke length(about 1-1/2" needed they say) in the MC. When adapting an NV4500.
I did see a thread recently on 4btswaps about the hydroboost thing.
Brian
Brian,
Thanks for the reply. I am staying spring under with stock, wide-trac width axles and think I've got the oil pan clearance dialed in. Once the engine is completely installed I will replace the stock axles with D44s. I have a WT rear already out of an 86 CJ, but I need to buy the matching front. I may go with a Currie Ford 9" front as I think the third member portion of the axle housing is shorter (from the driveshaft yoke to the front cover) allowing more room between the driveshaft and pan. Worst case scenario, heat the pan a little on the passenger's side and dish it in with a hammer a half an inch. I am trying to avoid that though. I have a 4" BDS lift (came with the Jeep) and have added a 1" body lift. This seems to have given me perfect clearance for the trans tunnel, etc. without hacking into anything with a sawzall.
As for the rad, I bought a new three core CJ copper and had the bottom port moved from left to right to avoid any big plumbing jobs. I didn't want to run lines from one side to the other if I could avoid it. I'm also using a flexalite dual fan setup for that very radiator. From what I hear, these motors are easy to cool (too easy sometimes) so I didn't want a big engine driven fan running all the time. I will probably move everything (rad., air to air aftercooler and AC condenser) toward the engine to make it all fit correctly. There will still be the rad cutout in the grill/radiator surround, but I should be able to fab a three in one bracket and make it all look nice. Maybe I'll cap the rectangular cutout in the grill shroud to keep it from looking like it's missing something.
Regarding the clutch MC, the NV4500 requires a 7/8" bored MC. I'm not sure there is anything you could do to a stock CJ MC to give it enough fluid volume to push the slave. This is all per Scott at TN Diesel Conversions. I will check out the 4BT forum for answers to my hydroboost question. The 4BT forum is a little much for me though, pages of info to weed through for what I need. I avoid it because it's just too much info sometimes. Page of sticky threads to pour over. I'm fortunate to have a few very highly qualified diesel gurus to answer my questions saving me lots of forum research time. This hydroboost thing unfortunately doesn't fall under their umbrella of expertise. Maybe I should just add air brakes, way easier to work on and plenty of stopping power. I actually found a nice tractor trailer style, accessory gear driven air compressor that my power steering pump would mount to, $350 though. Maybe I will add that when I get the ARBs loaded into new axles sometime in the future.
Regarding the turbo downpipe, mine will be a very tight and we will probably end up using a slightly flattened section to clear the firewall. I will probably trim some of that pinch seam that connects the firewall to the tub down by the transmission tunnel to give myself another 3/4 of an inch. That was the last thing we discussed yesterday in the shop. My buddy's exact words regarding the downpipe were "I ain't worried about the exhaust, the exhaust is something we can make. I ain't changing everything around 'cuss the downpipe might be a little tight. It'll be a little flat, but we can make it flow just fine. How many miles did you put on the 97' powerstroke with that stock flattened downpipe?" To this I couldn't argue.
I paid $350 for that Jeff Daniels 4BT motor mount kit, but I am going to recycle the bread truck's mounts. If you are interested in the JD kit I could ship it for $250. It's a little heavy, I imagine freight would be $40+ on it. If you look on your frame just behind the shock towers there is a 1" or so hole. The JD kit allows you to use that hole (with a bolt through the frame side of the mount) to get everything lined up. Once it's lined up you can weld it in place. I'm using it for that, but getting unmachined angle to make my frame side mount. I didn't see the need to cut up a machined piece portion of a kit if I wasn't going to use the whole kit, that would render it totally worthless.
Frame plates rear:
Frame plates front:
Motor mounts, note the heavenly beauty! A little overspray because we didn't give the motor a complete paint job before it was installed.
The hydroboost unit off the bread truck was adapted to the CJ, now I just need to find a MC that fits under the hood. The bread truck's MC has a reservoir that's about an inch too tall for the hood to close. Van from Vanco brake systems has been really helpful in guiding me. He even gave me cellphone his number incase I ran into problems over the long weekend. I am really impressed he would offer to do that in today's environment of lousy customer service.
The chassis saver paint I used for the frame and under side of the tub isn't pretty when brushed or rolled on, but it offers great adhesion and protection. It will fade over time to a dull black.
I used a product called Quiet Coat on the firewall and on the underside of cab portion of the tub. It's a dull grey color (I thought it would be black), I will paint over it with black rust-oleum after the seven day curing period has passed. It is supposed to act like a dynamat. I hope to put a very heavy coat on the underside of the hood to curb noise aswell.
Down pipe cut to fit:
The trimmed fender well to accommodate the charge air cooler.
All three components, air-to-air, radiator and flex-a-lie fan fit, but it's tight. Custom brackets will be made to hold everything up. Note the heavily trimmed grill/radiator surround to allow for the charge air cooler.
2 pictures....lots of red "x's".
Sorry....
I can't seem to figure out why I am running into this problem! I use the same method to post photos everytime, sometimes it works sometimes it doesn't.:shrug:
I just tried to re-copy and paste all the photos in the usual fashion, with the little mountain and sun tab, maybe it works now? The tough part for me is all the photos show up. I can't help but wonder that it has something to do with the http:// portion of the address already being in the address box, which I delete, since the address I paste already contains it.
all pics work for me... LOOKS AWESOME!!!
I think it's time to upgrade my account! This should eliminate my picture problem.
I need to replace my shocks. After doing a little research, the jury is still out for me. Are Bilstein shocks worth the money? They would be replacing BDS shocks for a 4" BDS lift.
Thanks, Charlie
Not from my experience, but from watching others with them and hearing their comments, Bilstein and Fox are well worth it. Especially since you have added weight up front, you can dial in the shocks front and rear to meet your needs.
Thanks Matt, I'll do a compare and contrast on both brands. I never even thought of FOX. The dial feature would be handy with an extra 300lbs up front.
Clutch MC
Charlie-
Going back a couple pages...... Did you determine what clutch MC you plan to use? I know the 5/8" bore Jeep CJ MC will not move enough fluid for the Dodge NV4500 slave, but did you find a "drop in" replacement that bolts right in the CJ set up? I was going to make a run to NAPA and search the shelves to find a 7/8" bore with the same pusher rod configuration as the Jeep CJ MC if no one had done this already.
Thanks and keep up the good work. My swap very similar to your powertrain. My post is on the 4BT swap site but I don't update nearly enough. I am still working on getting the engine equipped with the A/C compressor and motor mounts.
http://www.4btswaps.com/forum/showthread.php?t=9427
Rodney
Rodney,
Great build! Coil over 8 with a P7100! I must say I'm a but jealous.
I never tried to find a drop in replacement for the CJ clutch MC, but did make a stock Dodge Cummins work. In fact, that was one of today's accomplishments. I had to drill new holes in the firewall, but the clearance is there (it's tight, but do-able). I bought all the stock Dodge Cummins parts (bellhousing, clutch master and slave, etc.) from Scott at Tn diesel conversions. The Scott that is all over the 4BT forum. He's a good guy and has been very helpful with my build. I will take some more pictures on Friday and post them to my new upgraded, CJ-8 account. Maybe that will reduce the whole red x issue. I have a feeling a lot of that has to do with me not having a properly setup Picassa account.
Be careful with the A/C mounts. As I've found out, one little adjustment to something on this motor will throw a bunch of stuff off. I do want to run A/C for next spring/summer but think I'll need to try a Dodge Cummins configuration as the hood clearance will prohibit a high mount A/C compressor. Are you going to use the fan setup you have pictures of on 4BT? With an intercooler and radiator I didn't have room to fit one, but was able to re-use my flexalite fan setup. It's very cool that there are like 5 of these 4BT swaps into scrambler going on right now between 4bt.com and this website. Good luck with your build!
Charlie
A/C set up
Charlie-
I am going to run the Dodge AC set up also. I am modeling my setup after Scout4bta on the 4btswaps site. He did really good work and made his own AC bracket that also incorporated the motor mount. I don't think I could do any better than him and I also like the low AC mount configuration. I think I have a lead on a guy here local that I will buy all the parts from.
Rodney
Alright Fellas,
Hopefully, with my new upgraded account, red Xs won't be an issue.
Finished motor mounts. We made a new cross member out of 2"x3" 3/16"s wall tubing.
This will be the short run we need to plumb for the hot water exiting the motor.
Top view of motor, air-to-air and radiator fit.
Tight drive shaft clearence even with 4" of lift and 1" body lift. We've tried everything to get the shaft to hit the pan, including having two of us (500lbs) stand on the front cross member and jump up and down. It gets close, but still won't hit. Even if I jack the passenger's side front wheel of the ground until the driver's comes off, the pan won't hit the drive shaft. The first tough trail ride will be the test. New drain plug to replace the old one (with ginormous nut welded on).
I've made quite a bit more headway in the past few days and should get photos up today or tomorrow. Thanks for looking-Charlie
Keep up the fine work, Charlie :cheers: I am glad to hear you will be tackling the ac compressor engineering, I was not looking forward to figuring that one out.
Regarding your front driveshaft clearance, one more thing you might want to try is to jack up the left rear tire, then lift the right front as high as you can = the additional leverage will load up the F.R. more than just lifting the front alone.
TJ
More progress. It's almost running. I am awaitng the arrival of my hydroboost line kit from Vanco before I start it up. Very stoked about the Tomken dual battery tray. It really sets the engine compartment off.
Note the stock 4.2L oile pressure sending unit to match the Ohm range needed for the stock water temp guage.
Though it's hard to see, I eliminated the copper wire sensored Flex-a-lite fan module by making my own with a 195 degree switch in the water jacket wired through a Freightliner style 50 amp relay. When finished the Jeep will have an On/Auto/off switch for the fan. The off for deep water crossings, auto for obvious reasons and on for thinking ahead.
Guages under the radio; Mechanical water temp (copper wire, out of the bread truck), EGT and Boost. I wanted to cut them into the dash, but the placement of the defrost duct prohibits putting two guages above the oil pressure and voltage guage. I decided to go with a cheep autometer below the dash setup for now. When the AC unit goes in I will need to do something within the dash panel.
I bought an Acme top locally, then had a friend paint it, I'm just not that happy with the color I chose. Bilstein 5150s going on as well as Currie greaseable shackles in the rear.
Again, thanks for looking. Any help or suggestions are always welcome.-Charlie
