Brian,
Thanks for the reply. I am staying spring under with stock, wide-trac width axles and think I've got the oil pan clearance dialed in. Once the engine is completely installed I will replace the stock axles with D44s. I have a WT rear already out of an 86 CJ, but I need to buy the matching front. I may go with a Currie Ford 9" front as I think the third member portion of the axle housing is shorter (from the driveshaft yoke to the front cover) allowing more room between the driveshaft and pan. Worst case scenario, heat the pan a little on the passenger's side and dish it in with a hammer a half an inch. I am trying to avoid that though. I have a 4" BDS lift (came with the Jeep) and have added a 1" body lift. This seems to have given me perfect clearance for the trans tunnel, etc. without hacking into anything with a sawzall.
As for the rad, I bought a new three core CJ copper and had the bottom port moved from left to right to avoid any big plumbing jobs. I didn't want to run lines from one side to the other if I could avoid it. I'm also using a flexalite dual fan setup for that very radiator. From what I hear, these motors are easy to cool (too easy sometimes) so I didn't want a big engine driven fan running all the time. I will probably move everything (rad., air to air aftercooler and AC condenser) toward the engine to make it all fit correctly. There will still be the rad cutout in the grill/radiator surround, but I should be able to fab a three in one bracket and make it all look nice. Maybe I'll cap the rectangular cutout in the grill shroud to keep it from looking like it's missing something.
Regarding the clutch MC, the NV4500 requires a 7/8" bored MC. I'm not sure there is anything you could do to a stock CJ MC to give it enough fluid volume to push the slave. This is all per Scott at TN Diesel Conversions. I will check out the 4BT forum for answers to my hydroboost question. The 4BT forum is a little much for me though, pages of info to weed through for what I need. I avoid it because it's just too much info sometimes. Page of sticky threads to pour over. I'm fortunate to have a few very highly qualified diesel gurus to answer my questions saving me lots of forum research time. This hydroboost thing unfortunately doesn't fall under their umbrella of expertise. Maybe I should just add air brakes, way easier to work on and plenty of stopping power. I actually found a nice tractor trailer style, accessory gear driven air compressor that my power steering pump would mount to, $350 though. Maybe I will add that when I get the ARBs loaded into new axles sometime in the future.
Regarding the turbo downpipe, mine will be a very tight and we will probably end up using a slightly flattened section to clear the firewall. I will probably trim some of that pinch seam that connects the firewall to the tub down by the transmission tunnel to give myself another 3/4 of an inch. That was the last thing we discussed yesterday in the shop. My buddy's exact words regarding the downpipe were "I ain't worried about the exhaust, the exhaust is something we can make. I ain't changing everything around 'cuss the downpipe might be a little tight. It'll be a little flat, but we can make it flow just fine. How many miles did you put on the 97' powerstroke with that stock flattened downpipe?" To this I couldn't argue.
I paid $350 for that Jeff Daniels 4BT motor mount kit, but I am going to recycle the bread truck's mounts. If you are interested in the JD kit I could ship it for $250. It's a little heavy, I imagine freight would be $40+ on it. If you look on your frame just behind the shock towers there is a 1" or so hole. The JD kit allows you to use that hole (with a bolt through the frame side of the mount) to get everything lined up. Once it's lined up you can weld it in place. I'm using it for that, but getting unmachined angle to make my frame side mount. I didn't see the need to cut up a machined piece portion of a kit if I wasn't going to use the whole kit, that would render it totally worthless.
