Robert Slone
- Spring Hope
- NC
After reading cincyjeeprs thread I figured I ought to own up.
About a year ago i kept smelling gas from my gas tank. Turned out that gas was splashing (seeping ) out around the sending unit so I dropped the tank used some sealant around the ring and seemed to have solved the problem...except
I put the sending unit in wrong so the gauge would only show about 1/3 tank. But it worked from 1/3 down to empty so no big deal. Then over the summer I began to smell gas again, this time it was the plastic vacuum line fitting stripped out. I dropped the tank again (before I realized what the problem was) and replaced the fitting. But
in the process I broke one of the tubes off the sending unit. So I replaced the sending unit while the tank was out and put the tank back in. Turns out the tube on the sending unit was too short and was supposed to have a filter sleeve on the end so it sat in the bottom of the tank. I didn't catch this because the old sending unit was longer and didn't have the sleeve. Ran out of gas with the guage showing 1/8 tank. Soooo...drop the tank again
. Now it's fixed.... right.
Well while test driving it after getting the tank back in (I didn't mention draining the gas out of the tank after getting it out each time to lighten the load so i could get it back in..then dragging out the funnel to put the gas back in. Several gallons of gas get awfully heavy on a bad back) I saw that the water pump had sprung a leak
. Got a new pump, pulled the radiator,fan and water pump and put hte new pump in. I replaced the belt at the same time. Cranked it up , drove to town and got out to see anti freeze dripping everywhere. I forgot to put sealant on the engine side of the gasket
Went home pulled everything again and saw I needed a new gasket. Ordered one from CQ which came in the next day. Put the pump on, fan on and radiator in and cranked it up. No leaks!
Two days later I drove to town and came home and
smelled antifreeze. I raised the hood saw the leak at the heater hose...I hadn't tightened the clamp tight enough
Everything is ok now. Scrambler's running fine again. And NO i wasn't
or
. Now it's fixed.... right.Well while test driving it after getting the tank back in (I didn't mention draining the gas out of the tank after getting it out each time to lighten the load so i could get it back in..then dragging out the funnel to put the gas back in. Several gallons of gas get awfully heavy on a bad back) I saw that the water pump had sprung a leak
.Everything is ok now. Scrambler's running fine again. And NO i wasn't
or
