What color is your Scrambler?
What Color is Your Scrambler?
  • Red or Orange
    Votes: 105 18.1%
  • Dark Blue or Light Blue
    Votes: 79 13.6%
  • Camo
    Votes: 6 1.0%
  • Black
    Votes: 74 12.8%
  • White
    Votes: 55 9.5%
  • Yellow
    Votes: 31 5.3%
  • Dark Brown
    Votes: 36 6.2%
  • Green
    Votes: 49 8.4%
  • Tan or Beige
    Votes: 60 10.3%
  • Other
    Votes: 85 14.7%
  • Total voters
    580
'85 Laredo
red mistress said:
Seller CJ7 & CJ8 went all out, I'd really like to see more interior and underhood pics....please sir.QUOTE]
You did what I couldn't, showed restraint. After looking around and checking prices, I knew it was a good deal if the seller was representing it honestly. If anything, he understanded how good of condition it was in.
Yes, "Seller CJ7 & CJ8", is now only "CJ7". He did an excellant job on the restoration. :) He was also a great guy to do business with.:) It wasn't a frame off, but the underside is in real good shape as well. Let's just say I'd eat off of it. Had the frame been done it would definitely be a show truck. I probably wouldn't have been able to afford it.
I will have to take a few more pictures and resize a few, but I will try and post some of the interior and underhood.
I don't want to silence your thunder, because your '85 Jeep is super nice. However, if I were the guy whom modifed your Scrambler, I would have taken a few more simple steps to complete the Laredo clone. This would make it less obvious to "purists" that your Jeep wasn't originally a Laredo optioned CJ8. Although 9 out of 10 Jeep folks won't care, there are some that might truly appreciate the care and attention to detail that is involved in making an exact clone of an original Laredo-optioned Scrambler.
I hope that you'll notice from my comments above that this is not to indicate any negativity towards the current owner, as I put that negativity on the guy who didn't complete the full cloning process. Your Jeep is very nice looking. If I were to have the opportunity to own it, I'd complete the cloning and make it "perfect", or less obvious to Laredo folks, at the least.
Complete the Cone
No negativity taken, no matter whom it might be directed toward. We are all entitled to our opinions. My opinion being no more important than yours, the dominate factor in this case was MY money. I was totally pleased with what the PO did with the Jeep, and the manner in which he represented what was done. What he was selling was exactly what I was looking to buy. I can totally appreciate that what he was selling was not what you would be looking for in a Scrambler.
My curiosity is up though. Share with us what those "few more simple steps" are, which you believe would complete the "cloning" process. I was unable to detect anything which was lacking or added whcih fell outside the realm of a Laredo option with the exception of the radio. So, educate me on what more I should be looking for.
Thanks-
Gary
...I was totally pleased with what the PO did with the Jeep... ...what he was selling was not what you would be looking for in a Scrambler.
...those "few more simple steps" are, which you believe would complete the "cloning" process.
Thanks for your constructive response, Gary. I would also be pleased with your Scrambler, and that is why I noted how nice is the appearance of your Jeep and what would be done to it if I were fortunate enough to own it. However, I think that you misunderstood my previous post to indicate that I would not desire owning your Jeep. That is not correct. Even though my post may have sounded derogatory, it was only meant to indicate that your CJ8 is very close to being an identical clone of a Laredo-optioned model.
The few simple items, to which I alluded, would be the addition of the correct steering wheel, the underhood insulation and the day/night rear-view mirror. These simply items would make your CJ8 indistinguishable from original Laredo models, since there weren't any VIN identifications used by AMC to separate Laredo models from the others.
To go a bigger step further in order to appeal to purists, I'd remove the glossy bolts from the rear tire carrier area and bump-stop, and replace them with the body-colored carriage-head bolts and black hex-head bolts for the bump stop. I'd also replace the bolts and screws that anchor the wooden side boards with the correct torx-head bolts and screws (red bolts on the rear, and black screws on the bar). I'd also consider switching the spare tire location and mount it on the swing away carrier, although I don't know if this was a specific Laredo option. However, I haven't ever viewed a stock Laredo-optioned Scrambler with the tire mounted to the roll-bar. The items noted in this paragraph are minor compared to the three items found in the previous paragraph.
By the way, Gary, what are those black painted parts mounted near the lower door hinges that are seen in your photos of the exterior body?
Good Feedback
Point taken. Didn't mean to say you wouldn't want to own it, meant to say that you would be looking to make those few changes you listed below. And again, I didn't take anything you said as negative. We had a previous conversation about purist, and I don't have a problem with that.
The few simple items, to which I alluded, would be the addition of the correct steering wheel, the underhood insulation and the day/night rear-view mirror. These simply items would make your CJ8 indistinguishable from original Laredo models, since there weren't any VIN identifications used by AMC to separate Laredo models from the others. What was incorrect about the steering wheel? It is the leather wrapped style. You are right about the underhood insulation and rearview mirror. As well as the console we discussed previously.
I did purchase and install a swing away tire carrier. But after reading the info you provided, I didn't get it exactly right. (bolts/nuts)
I asked because I wanted to educate my dumb self. Your initial compliments didn't go un-noticed, nor your feedback taken negatively, both are appreciated.
Thanks again for your follow up, Gary. The Laredo steering wheel has leather wrapped spokes, as well as the wheel, and the "typical" Laredo horn button that is also found on FSJ Laredo models (it has a number of simulated round hex-female screws circling the Jeep logo). I'm not sure if the FSJ horn buttons fit Scramblers, but I bet they would, simply due to commonality of parts AMC employed during that era. I only have about two or three pictures of my Jeeps, so I don't have one that shows the Laredo wheel. Hopefully, another member can post a picture of their Laredo steering wheel.
EDIT: I found a photo of a Laredo steering wheel on an eBay CJ8, for your reference. Also, note that the speedometer on this CJ8 is not of the correct vintage for the '81 model CJ8, the hood stripe kit is not complete and there is a strong indicator that the Jeep has more than 60K original miles, barring unusual circumstances -no matter what Carfax indicates. :)
http://cgi.ebay.com/ebaymotors/Jeep...ewItemQQptZUS_Cars_Trucks?hash=item2303c48444
I didn't understand your comment about installing the swing-away carrier, and not getting it installed correctly. The bracketry is black and is the same finish as the carrier, as well as the bump-stop that is located near the fuel cap area -all black. On my '83 Laredo, the roll bar has the preparation to mount the spare, but the holes are plugged or haven't ever been drilled -they have round dimples where the holes would be located. I bet a welded carriage bolt head would replicate this detail on a roll bar that has been drilled.
In regards to being knowledgeable about the Laredo options, I've had mine since I was 18 years old, and I still appreciate learning new things about the varying options that AMC provided in the Laredo models. This may be one of the reasons why some of my posts seem objectionable, as it often times generates the incentive for good rebuttals from fellow members, which inevitably becomes a good learning experience for me and others.
By the way, I guessed about your rear-view mirror, as none of your pictures show your mirror -it was a lucky guess, but it is also a common part that is omitted from restorations. My '81 doesn't have the correct mirror either, because somebody stole it off the windshield about 15 years ago -I should have had some of those mirror locks like you do for your doors. :)
The only thing I was saying about the spare tire carrier is I used the carriage bolts you saw in the picture. When I bought the Jeep there was no swing spare tire carrier, only the rollbar mounted one, which does include a bracket that slips over the rollbar and bolts. In addition, it had the bolts for the swing away tire carrier and bump stop bracket as well, mounted in the body. I just used what was there, which apparently are not OEM correct.
The mirror does have the high beam flip tab on it. Whether or not it is OEM, I don't know, and since I have sold the Jeep I'll never know.
The mirror does have the high beam flip tab on it. ...I have sold the Jeep I'll never know.
That is the correct day/night mirror, if it has the flip tab, so my guess was inaccurate. I didn't know that you no longer owned that Jeep, Gary. How long did you own it and why did you sell it? Everything I've indicated seem to be moot, now that you don't own it anymore. :(
I owned it about a year. Long story on why I sold it, had to do with losing use of a company truck, the Jeep becoming a daily driver, plus having a few other toys. Bottom line, sold all my toys, bought a new Jeep Wrangler, now my daily driver and not having any payments.
But I didn't consider it a moot conversation. You educated me considerably, and when I get my next Scrambler, I will know! Thanks!!!
Sherwood Green Metallic, repainted in factory color about 10 years ago.
That green is such a nice and unique color, Spank. It reminds me of the Laredo that was listed for sale on this forum about a month ago, and the guy never did send me any additional information. :confused: I like the way your wheels look with the contrasting rings; it mimics the old two-piece wheels of yesteryear.
The second picture you've posted shows the correct rear bump-stop plugs that are used when the tire is mounted on the roll bar. This was discussed in some of the previous posts, but it was hard to explain how the heads appear like carriage bolt heads. Thanks for the pictures.
BTW, I see that you don't carry a spare tire.
Since those pics I have added the factory roll bar spare tire mount. I still have one of the original Good Year tires for a spare, with a matching painted rim and chrome trim ring;) I also added a factory chrome rear bumper. I think this Scrambler originally came with the standard swing away spare tire mount on the back. The previous owner gave it to me when I bought the Jeep. It was damaged so I did not use it. The roll bar mounted spares are just another way the Scramblers are more unique then the standard CJ-7's and 5's:thumbsup: I'll post up some new pics soon;)
That Laredo that was for sale on here was bad a$$ :-)
Roll bar mounted spare tire carrier and factory chrome rear step bumper pics.:D
As for identifying original Laredo's by the VIN- It's easy look on the firewall vin plate, under Toledo Ohio you'll find a groups of 2 digits, That's the paint code - 3B=Sebring Red
Next you'll find 3 digits, That's the seat code - 1BJ=Black, High Back, Italian Purse (W/Vertical Straps)
A nutmeg Laredo will be 5EJ
A honey Laredo will be 9EJ
I used these codes to identify every potential Laredo that I was considering buying.
Mines Red....originally Lt. Blue aparently.
Gonna change it though....I've had enough red Jeeps.....anyone have any sugestions?
