81 or 83/84 cj8's
Capt.Dan
Nashua
NH
I was wondering what the plus's and minuses about a 81 vrs 83 and new cj8s. I know 81 comes with a narrow track. but what else is there? Will a 81tub fit a newer cj8? And has anyone tried to put on a tj unlimited tub on a cj8?
Thanks Dan
There is a thread in the history section that discusses the diferences in '81 and early '82 vs late '82 and newer scramblers.
For the most part any scrambler is the same as any other impo.
A LJ tub is shorter than a cj-8, so some custom fab work would be required.
...And has anyone tried to put on a tj unlimited tub on a cj8?
Thanks Dan
The LJ is 9" shorter between the back of the rear wheel wells and the rear of the tub, but that's not the hard part - the body mounts are in completely different locations and the TJ/LJ frame is a lot wider than the CJ frame, so the hard part is adapting the LJ tub to the mounts on the frame, not the length of the tub.
I've seen a thread or two on other boards about putting a TJ tub on a CJ-7 frame and it's not pretty. One I remember they had to build a sub-frame under the tub so they could get mounting points located wide enough.
