Charlie's cummins diesel transplant thread
Winter blend does suck when it comes to fuel economy, not to mention driving through cold air. (more dense than warm air)
I sold my Dodge Charlie, buying another Scrambler, a driver this time. it's in Fla. Going to pick it up next weekend, Jan. 1.
Awesome Doug. Pictures soon to follow I hope.
dana 60/70
Hey Charlie,
Noticed in another thread you went with 37" MTRs. What are your plans for axles?
I will have available the dana 60 front and dana 70 rear out of my 1 ton dodge W250.
Unfortunately, they won't fit the M725, let me know if you're interested. Lee
Lee,
I didn't end up buying the MT/Rs. When I went to look at them (there was no way I was paying that shipping rate) they had been misrepresented as being new, though after re-reading the add the seller did give himself a good out. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=200327100001&viewitem=&sspagename=STRK%3AMEWAX%3AIT
When I got there to pay for them I was sorely dissapointed by the fact they were more than half worn and badly cupped.
I'm not sure what I'm going to do yet for tires, but it'll end up on 36"-37". More than likely SSR's or KM2's. I like the older MT/R's but they've been discontinued. Thanks for thinking of me, but I shouldnt be needing axles as I have a 3/4 ton Chevy Dana 44 for the front and a Ford Dana 60 for the rear. Both of which are going up to Mitchell Diff to get narrowed to a little wider than WT width and have ARB's installed. I'll keep you guys posted as progress gets made. I also bought a M.O.R.E. SR kit to put on, so I've got some work to do. Where's the best place to get new lower spring plates and u-bolts for my 2.5" wide alcans? I need to get a pair to install my current D30 while the Dana 44 gets built.
Hey Charlie...
Damn good job on your 8!
I am getting back on mine; agian. My questions are:
Did you modify from stock; if so how much and what did you mod.?
How much boost are you getting?
How did you do the snorkel? Would you do it the same way again or change the plan in someway?
Thanks for any help you can offer- Brian
Hey Charlie...
I am getting back on mine; again. My questions are:
Did you modify from stock(engine/turbo); if so how much and what did you mod.?
How many RPM's @70'ish?
I had Diesel Fuel Systems in Bangor, Me do a basic fuel pump rebuild and turn the pump up as much as they felt would be safe and effective which was 30%. It also has 300 horse injectors with a 155 degree spray angle (I think). All in all, with the difficlulty I had fitting the air to air, I'm not sure I'd mod the motor again. Even my fully kitted jeep for multi-day expo type wheeling trips weighing close to 6000lbs would be well powered by a stock 105-120 horse motor.
The turbo only really blows appreciable boost, maybe 10lbs when I am basically "drag racing" from a light or stop sign. On the highway it negligable. The engine has enough power that it doesnt really need to blow boost unless I am absolutely romping on it, which isn't very often.
The snorkel is an absolute work of art (in my humble opinion). I have access to a local welder who works for the regional ferry company come down to TIG that together because I can't TIG weld. He's really good at making custom tuna towers for sport fishing boats so the snorkel was within his realm of capability. It's made from 3 1/2" 1/8" wall aluminum tubing, but I'd probably go 3" if I did it again. There are five (5!) compound bends in that snorkel that were absurdly dificlut to get right. In other words, I have no idea if I could make another even if I had to for one of my own projects. The problem is aftermarket snorkels for CJ's and YJ's are all for driver side intake motors, the 4B is passengers side and I don't like extra plumbing-not that there is much room to begin with. The actual air cleaner box was tough to get right and frankly I'll likely re-do it at some point. Right now it's just below the battery tray and it can't be accessed from the top without removing the battery. It's the only spot in the engine bay where there's room for a filter, but it's very innaccessible.
Well, I havn't put the tach in yet, but the old gasser I had in there turned around 1750 rpms at 70. I havn't changed any of the gearing, tires, etc. so the 4B should be the same. I'm going to re-axle and tire soon and should be going from 3.31 gears to 4.10's or 4.33's and from a 33" tire to a 37". In a net total, I need to increase my ratio a bit because 1st gear in 4-hi is a little too quick. Ultimately, I'd like to be turning at or just under 2000rpms while doing 65mph. There is a great gear ratio calculater that I'll use to do my final math. http://www.grimmjeeper.com/gears.html
Thanks for the kind words.
your jeep makes me more jeloeus now that i am deployed. it is looking pretty good, wanna sell when i get home:-p
Ok Guys, I need some help. Please!
I am diligently working on sourcing parts for this project, but have hit a snag. Below is the problem.
I have a 4BTA currently set up for a ford manual (from an Oshkosh bread truck) that I am trying to mate up to an NV4500 that I already own. The NV4500 has been converted to work with the chevy 350 already in my Jeep (with Advance Adapters bellhousing). I want to set up the NV4500 and 4BTA in a stock Dodge Cummins arrangement like it would have come from doge in say a mid 90's 4X4 manual. Can anyone direct me to a definitive thread that will help me with this or answer my questions here?
I need to figure out exactly what parts I need to source for the Dodge Cummins setup. I know I will need a bellhousing, input shaft, retainer and starter, but what else? There is currently some sort of adapter on the motor that mounts between the block and the bellhousing. Is this a universal adapter or specific for the Ford bellhousing. I imagine I need to get a different one to work with the Dodge Cummins NV4500 bellhousing, but don't know a part number, etc.
To be candid, this is the exact same post I put up on the 4Bt swaps forum. What I need to figure out is if a mid 90's Cummins powered Dodge pickup has a 2"ish aluminum adapter bolted between the engine block and bellhousing. I imagine it does, but I can't seem to figure out a part #. Does anyone own a mid 90's Dodge Cummins pickup with a manual transmission? If so, could anyone give me some feedback and maybe a part # or PM me a VIN to call a Dodge dealership with? My uncle had a 96', but totalled it when someone crossed the median and hit him head on in a snow storm. I am thinking a Dodge Cummins pickup will have the adapter, maybe considered a flywheel housing, but it may be different from what came with my 4BT/Ford T19 trans setup.
I would be very greatful if someone could help me out. Any leads would be really appreciated.
Thanks!-Charlie
Hey Charlie,
I'm leaving for work soon so don't have time to read all 8 pages of this thread right now, but was wondering--did you ever get your adapter mentioned in your quote above? I used to own a 2001 Dodge Ram 2500 with the Cummins/5-speed combination but got rid of it in 2008, but I'm still a member of a message board for Dodge Cummins trucks similar to this one. The website is dieseltruckresource.com, and they have a wealth of information there and people that are willing to help. They should be able to answer most any question you have about your 4BT that would also relate to the 6BT or ISB diesel motors. So far from what I've seen your project looks great and I hope to do one myself one of these days. HTH
Thanks for asking about the adapter. She's all back together and running though. I found a stock adapter at a performance shop that someone didn't need when they had a peformance clutch installed. Thanks for th compliments.
Xer0, good luck with your deplyment- I wish you a safe and speedy return!
So...?
Hey Charlie -
Haven't seen anything lately about the new romance...Still on your honey- moon?(w/the JP)
I was wondering how you like your engine mount and if you'd do it the same again?
Also, do you have a part number for the hydraulic isolators you used?
Overall hows the vibs?
About to copy you're set-up soon, unless you have advice to the contrary.
Thanks - Brian
someone's gonna get slapped..?
FNG...Wow...too funny. You went right from talking about a honeymoon to mounts, isolators, and vibrations...LMAO!!!!:rotfl::rotfl::rotfl::rotfl::rotfl::rotfl::rotfl:
Having never seen one of these swaps in person, but read about their popularity, I was really surprised to see them listed in the less-preferred swap article in the newest JP (They were being overly dramatic with their actual article title, so I'm paraphrasing based on the nature of the article).
They cited too much noise, vibration and fumes as reasons not to go this route... but sure seems to me noise and vibration are already a CJ thing, so what's the big deal??? :D I'd LOVE to get a ride in this someday...
Well>>>
It seemed a natural "marriage" - given the photo of the t-shirt, back in charlies thread - about supporting single mothers! :thumbsup:
You know Bigwalt-
I have noticed that the boys writing that rag seem to have a thing against diesel's in jeep's period. I don't think they have missed an op to offer their opinion on the matter(agianst the diesel swap). Hopefully, I will be able to give you a much more informed opinion sooner than later...
You know Bigwalt-
I agree, they seem set on the fact that a diesel only should be in an FSJ. They were also against the GM diesel swaps too. (I really freaked out that they had the 4.0 swap in there until I realized it was in the context of a 4cyl Wrangler to 4.0, which I actually agree with them about).
Screw that :D I say that if vibration and noise are going to be a problem for you, drive a Patriot :rotfl:
I'm think'n let 'em drive a KIA!
However, they did like a J20/4bt conversion....I did too-actually!
The whole diesel thing-in a small package (4cyl) seems such a natural in a Jeep.
Not too many 4cyl could I switch to and be able to just about triple my torque output-with a stock engine and have all that torque under 2k rpm...I'm just say'n...
Hey Charlie -
Thanks - Brian
Brian,
My sincerest apology for the slow reply. I regret to say that I haven't driven the Jeep since December. It's been sitting in my shop awaiting narrowed axles. I can't really drive it until they're done (D44 front/D60 rear) as the stock housings' pinion seals are both leaking pretty badly and I need to isolate a vibration in the driveline. I think the driveline vibe may be the stock rear about to implode, I don't know. The Jeep should be back on the road in June. Work has been incredibly busy this year so I may need to find a local shop to finish everything for me. I've done all the work myself so far, but installing the SR kit up front and installing the new axles may have to get farmed out. I just want to drive it!
Regarding the isolators, i don't have a PN, but I'm pretty sure you can get them through Freightliner as they're the dealer for Oshkosh chassis now. Call Tri-state freighliner in Shrewsbury, Ma and ask to speak with Scott. I've seen them on ebay for $60 or so used, but I'd be willing they aren't much more new. They are the way to go. PM me if you are doing a similar project, I'll give you my # and answer questions that way. The same goes for anyone, if you are actually doing this conversion and not just in the "planning" stages; I'll help where I can.
CHeers, Charlie
Guys,
Regarding the swap; I'm really happy with it. Frankly, it's a badass conversion and is great for an expo-rig. The guys that write JP mag are probably the guys that think it's cool when you can get all four of your rig's wheels off the ground while out wheeling. If you're a fella who wants his CJ to sound and smell like a 69 camaro, put a 350 in it. It does vibe more and it's loud, but frankly they're loud anyway. Over 55, the road noise drowns out the engine regardless of the fuel type. "the bread truck" as the guys in VTXS are calling it, was getting 20+ mpgs when I parked it last fall. That's almost double the carbed LT1 it had in it. The only advantage the LT1 had over the diesel is speed off the line. The 4bt does great but isn't as quick. Off-road the 4bt is so far and away superior to the gasser for low end contolled torque that there isn't even a comparison. It now feels more like a log skidder in the woods than a jeep in the torque department. When the trail gets dicey I like to be able to have an exact connection with how much power I apply to the wheels to keep from spinning tires and the diesel allows me to do that.
Gotta love single mom's;)
