As the coin flips
kohldad
Goose Creek
SC
So does my decision to sell the Scrambler. And until it lands, no one is for sure what the final outcome will be.
I've decided instead of selling it, to drop another grand into it and fix the things that annoy me and hopefully finish it as much as a jeep can get finished.
I plan on putting the money into the following:
Fix the driver's side ball joint which I discovered had 1/2" play last week - completed 2/19
Fix/replace the fired passenger seat for Linda.
Stainless steel brakes lines to firm it up the brakes
Replace the steel fuel and brake lines that run along the rails - fuel line received, brake line cancelled
Homebrew a conversion to rear disc w/ebrake (looking at Grand Cherokee and Rodeo) - new drums & shoes fixed the brakes so postponed 3/21
And the big money eater - fuel injection system of some sort, either an engine swap (4.0, 4.3, 5.3, 401) or at a minimum and probably the route I'll go, 4.3 TBI w/4.0 head.
Reason for the change is Linda has started taking short rides with me, actually insisting we take the Scrambler. Yes, there is a reason for this, she is trying to convince me to let Stephanie take the Grand to Clemson.
Also, my father will not be gone for 6 months next winter, so I hope to make a few wheelin trips with him. With my history of commiting and not showing up, I'm not going to commit to any event, but who knows where I'll show up.
:cheers:
You better keep it. Every time I watch another episode of xtreme4x4, I either see you or your daughter driving around with smiles on your faces.:thumbsup:
:cheers:
Right On! :cheers:
Fixed the ball joint issue. Took me four nights to get everything done. Of course, one of those nights was wasted trying to push the ball joint shoulder through the knuckle. When I went the correct way, it almsost dropped out with a few taps of the hammer. :banghead:
Had a guy from PA that inquired about flying in to drive it home. Sure am glad he didn't buy it. When I was doing the ball joint, discovered the inside bearing was rusty and was just barely turning, another 100 miles or so and it would have froze. Not bad though since I hadn't checked them since I put the axles under the jeep in Jan 04 and have 20K miles on them.
Fuel line was ordered and sitting in the bed of my truck for installation. Decided while ordering to upgrade to the 3/8" line so I'm set for any future engine upgrades.
Decided not to do the hard brake lines, saving the money on those for other upgrades.
Way to go Eric. Glad to hear that you decided to keep it. As far as engine upgrades you might want to consider doing the 4.5 stroker, it's an easy build and fairly cheap also. Give me a call and I'll tell you about mine. Call me any time between 9:00 am and 9:00pm.
502-713-9627
Don
