The little flatty--for a lil fella
I ended up drilling the seat mounting holes a tad bigger which really aided in getting the seats in/out. My origional size was just a tad too small and made for a workout to remove them.
But here is how they look with both seats in the far back position.
And both seats in the far forward positions. The passenger has 3 different locations and the drive has 5
And this was a hard one and took some thought. I looked at a number of locations to place the battery. Under the hood just was not an option. I looked at sinking it down between the seats but changed my mind. But here is what I came up with. Its close to done but I ran out of material for the retention portion of it. But it should do the trick.
Just saw this on Pirate, Crash- lookin good as usual! I might steal your center grab handle idea for my cage...it's in process now.
Ok I got the tray all welded up and the hold down portion all done. Its a super simple setup and should do a good job of keeping the battery where it belongs.
Got it jigged into place and burned in onto the rig.
And sits tucked nicely behind the passenger seat.
Ok--after a little bit of a burnout I finally got out from under it(still a little there so I am ramping back up to my origional pace).
So here is where I am starting. I went and drug the tranny and t-case dale had dropped off. Both these damn things are HEAVY and I prefer to work smarter than harder whenever I can so I grabbed the cherry picker. So lets start with the t-case. Its a rockwell t-case and I am not real familure with them but look pretty beef and an interesting case. The case apears to be close to a 300 in the length of the cast case--but the neat aspect of the case is the rear output drops in the bottom of the case. So me being me I HATE working with grubby parts and spent a couple hours cleaning the 3" deep(lol) of crap off it.
forum
forum
And all clean
forum
forum
I found the input seal in the t-case cracked(old) so I have to replace that. But for now I went and threw the t-case onto the sm420 tranny.
Ok for those of you who have toyed with these trannys you know how crappy they sit on a tranny jack due to how narrow they are at the base. Once you throw the t-case on you end up with a fumbling mess to keep chained on the jack. Well I work alone alot in the shop and I try to be safe whenever I can because one thing I don't want is one of my kids or wife to walk into a smooshed body..
So I have a ton of scrap angle material so I went and made a mount that fits onto the top of the jack X platform.
And there it sits on the jack with threaded pins--not going anyplace.
And there the whole works sits chained to the tranny jack and its DAMN secure.
I got the new PSC pump mounted on the bracket to check clearance against the orbitral and all looks good.
I got the tranny/t-case rolled under the rig and jacked up into place and yup--that adapter thats there certainly isn't going to work. But I was able to eyeball a few things I could only guess on.
Here is roughly where the tranny sits on the hole in the floor.
Underside
And here is an interesting thing and something I was hoping for with this t-case. Look at the pinion and output---wow. As it sits the shaft is 14" long.
So with it sitting there I can now get some better ideas of how this needs to be. Doing some measurements I want to roll the motor forward roughly 3 1/2". This will not only help with the rear driveshaft but I can then raise the tranny about 1" higher and still maintain a good angle on the whole setup. But alot of this rides on the radiator..
Ok so I went and got the radiator mapped out. I came up with a measurement of 15" tall max(from bottom of rad to top of cap) and roughly 24" wide from tank to tank with the lower inlet on the passenger side and inlet on the drivers side(typical GM configuration). For a fan we can run an electric pusher fan since there will be room in the grill area.
But the perfect location is.
On top of the crossmember in front of the motor. To get a radaitor of those measurememnts to fit I will have to trim the area behind the grill..
Ok my second attempt failed to get tabs for the harness's so I went and just made my own and burned them in.
:cool: Great to see this thread back in action, awesome work as always.
Thank you sir :smokin:
Ya still poking at it but pushing to finish the metal work so it can go home and have the paint work done--then come back for final items......
And went and test fitted them to make sure all was good. Perfect..
Hmmm...where have I seen such quality work before? Oh yeah, on all your other posts!!! It must be nice to be able to fab so well!:cool: Then again, I'm getting lots of experience doing everything two or three times!;)
As always, it's great to see your posts and pics!
-Mike
-Mike
:D:D Its an aquired taiste and takes alot of patience. I still don't know how I am able to do what I do. Heck you should see my RC rock crawlers,lol...
Who, Me?
You're the one with the Garage cam...;)
We have to meet up some day...:cheers:
One of these days randy. I am hoping to drag the family down south this summer--maybe we can hook up. Heck I haven't seen jeff in a long time also or my baby I built for him....
