ilovetrains
slightly backward
- Lee's Summit
- MO
After a rather long hiatus, I am back to working on my Scrambler project. This project started with the idea that I wanted a Scrambler with a modern drivetrain and suspension. I started with a 83 tub, and put it on a frame from an 05 LJ. The WB is 1/2 inch off, and we figured we could cheat that in the front end without problem. The engine and transmission are a 5.7 HEMI with 545RFE tranny from an 03 Ram. The Tcase is a 231 with SYE originally from an XJ. The rear axle is a 44 from an LJ and the front is a 30 from a ZJ (because we sorta had it laying around.)
The engine wiring is courtesy of coolwire and works well. I am ready to start on bodywork after getting it back from the muffler shop this past week. I think they did good work. We used the stock exhaust manifold on the driver side to clear the starter, and one from a 05 GC on the passneger side as it exits down at the rear, as opposed to the Ram which basically went straight back. I save the y pipe and cat from the Ram and with the addition of another upstream O2 sensor., it is on. The computer needs 2 upstream sensor, but could care less about donwstream. I am legal with the cat.
