Fiberglass Body
lamp3161
Greendale
IN
Got a line on a Scrambler that apperas to be in good shape except it has a fibergalss body. How much would that diminish the value? Tx
I think it depends. From my perspective, it decreases the overall number of people interested in buying the rig. However, I also think it increases the value of the rig with that smaller group. Personally, I would rather have a fiberglass body. I drive mine daily, and rust has been a real issue over the last 7 years...
Agreed.
If you look at how you asked the question, it appears you are in the camp that sees it as a negative, I think that's all the answer you need. Whatever you think the answer is on how much it decreases value is probably pretty good.
Not being mean, just being honest here, that's really a pointless question to ask. For me, I hate fiberglass bodies, but for lots of folks they see a Scrambler that will never rust. Even then though, the quesiton is what that does to the value to them. I'd bet it doesn't increase the amount they'd spend on a similar metal bodied-scrambler and I wouldn't be surprised if they'd actually want to pay less than market because they know there's people like me that would see it as a negative and therefore the value isn't what it should otherwise be. Not sure if that makes sense, just saying that the glass body folks are counting on a lower price because of the anti-fiberglass crowd.
I am the exact oposite. I would rather have the fiberglass body. If you live in the rust belt and actually drive your rig year round, there is no substitute for fiberglass.
A Scrambler that doesn't rust is like...it's like...well... it's just unnatural. If God didn't want Scramblers to rust he wouldn't have made them out of steel in the first place.:rolleyes:
I have one of each Steel & Glass. The glass is nice because it even looks good in gelcoat. It has steel doors with a glass top. No rust = A nice combination.
What?
God worked for AMC?LOL
If that was the case why did he:
-make amc 20 rear axles
-or bbd carbs
-or sr4 transmissions
-or stop making jeeps with v8 engines
-make amc go out of business
The list can go on and on.....LOL
Must have been after that 7th day of creation!
She works in strange and mysterious ways, doesn't She.
And on the 7th day, He Jeeped.
:rotfl:
The look and feel of glass is just wrong to me, the edges and corners just don't look right. If I were going down the path of a DD scrambler I'd save up a little more and go aluminum.
You still have the same issues with Aluminum... The edges and lines don't quite look right there either. And, aluminum still corrodes. Personally, I would prefer fiberglass...but, the tub I have is steel (and I can't find anyone to trade with)...so, I am looking for the best way to prevent rust from coming back. My rig went from rust about the size of a 50-cent piece to completely rusted and nearly unsafe to drive in 5-years (daily driver)...I just don't want to go through that again...
Don't feel like you have to defend your preference, to each his own :thumbsup: I totally get the practicality of glass for a DD.
Aluminum has issues, but I'd paint it and I think it's a good compromise. I've only seen one AL body on a buddies flatty and I thought all the angles/corners looked spot on. I don't think I've seen a Scrambler body in person though.
I am neutural on the subject of fiberglass or steel. Both have thier place.
As for the value, I would look at how the body itself is mounted to the frame, how the Doors are mounted to the body,and if it has the tialgate cutout or not.
I would also look at the manufacturer of the body, if its an AJ's body, especially one of his extream use Kevlar bodies, it may actually be worth more.
Start with all of the mounts, if you see major cracking in the glass (not just the gell coat) then chances are that that mount was done improperly and will fail.
Go over it carefully tally up what you find and counter offer accordingly.
Hope that helps.
well I can say I have a fiberglass body on my cj7 and It's nice. But If I had a mint OEM steel tub I would have gone that route 100%. I was in the market for a Mint OEM steel cj8 tub and they are hard to find! And there are a couple of guys out there that don't know what a mint OEM tub looks like(trust me I have had my time and money wasted on wild goose chases). But I did find a a nice 4WD hardware fiberglass tub for my wifes cj8 build and I am happy with it! But I can say If someone would trade me straight up for a true rust free, car accident free, unmolested cj8 OEM steel tub I would do it in a heart beat! I like the look of the floors and the under side of a clean OEM cj tubs.
But like you said there are other options (aftermarket steel, aluminium). And everyone knows the aftermarket steel tubs are not as strong as the OEM tubs. And the Aluminium tub looks just like a fiberglass tub and you still run the chance of the aluminium tub Oxidizing! So if this is going to be in the salt and a DD then i would go fiberglass!
7jeeps7kings
My larger issue is that I can't make up my mind. I like a lot of the maintenance issues of glass, but don't care for the overall "look" of glass or aluminum. Also don't like the thought of how much less it weighs... Ideally, I would find a way of keeping the steel (but not the rust):)
I never heard of somebody NOT liking how much less it weighs. Less weight equal better performance, gas mileage and the drivetrain gets less wear from stress. I am a big fiberglass fan due to living in new england. My 17 year old fiberglass CJ5 tub still looks new and is holding together very well. I am very happy with it and if I had a steel tub I would most likley be needing another replacement at this time but I do not thanks to the glass body. Scramblers do hold a better value than other CJ's but if you plan to keep it then do what is right for you. The vaule of my CJ5 is irrelevent since it will be staying with me until it dies.
My only issue with weight is snow. The Jeep already weighs very little; add in the wide tires, and you begin to hydroplane on snow very easily. It is downright embarrassing to be passed on the highway by a Honda Civic!!!
You have a point there. My Jeep does slide alot in the snow. But that just gives you an excuse to but a winch and full roll cage to add the weight back on. See problem solved.
