Build a New Scrambler?
Jared1956
De Soto
MO
Hey guys, I have been a Jeep owner most of my life (33 years old) and I have owned everything from a 46 2A to a 2005 Wrangler. I have been patiently waiting for Jeep to produce a Wrangler based pick up, but it doesnt look like this is happening anytime soon.....and with the quality of Jeep being less than ideal, I don't know if I would want one anyway.
I need a pick-up for work and home use, and I want another open top Jeep for cruising around in.....plus I am looking for a project......and another hot rod is not practical for where I live now.
So here is my idea I have been kicking around lately........build a new Scrambler using aftermarket frame and body, new axles, and a crate engine..... its something that I had originally planned to do with a CJ-2A, but couldnt justify the cost of that project as a toy only.
My budget is around 30k as this is what a new Jeep or Tacoma pick up would cost. I have cash available to finance the project.
I was thinking about using the following:
* Throttle Down Kustoms Frame with YJ spring mounts. YJ springs because aftermarket axles are available for the YJ configuration.
* New Axles (44's) for the YJ spring mounts
* New Reproduction Steel Body
* GM Crate engine 350
* NV-3550 or NV4500 Transmission
* Transfer case ???
* Factory interior, steering, gauges, paint and decals.
* Factory chrome rims with 31 BFG AT or MT tires.
I was thinking of buying a rusted out beater of a Scrambler for the title and tags, and to use for the misc parts and as a template for the new body. I would stay away from fuel injection due to increased cost and complexity of fuel system, and go with a simple aluminum intake and off-road carb. Painless wiring would cover the wiring and give me extra room for accessories like a winch, lights, etc.
I ran the numbers and I am right at 25-30k depending on the use of new or salvage yard drivetrain parts, and whether or not I attempt the paint.
I have a Millermatic 211 auto-set mig welder, compressed air, and all the tools I need with the exception of paint supplies. I have done all of the mechanical work with the exception of setting up ring and pinions, which I wouldn't have to do if I bought new axles.
So what do you think? Any ideas on specs for the frame......should I have anything custom done that would be beneficial? I was thinking just a factory spec frame, with the exception of V8 mounts and YJ springs, but I know there are options for higher body mounts, etc.
What Transfer case should I use? I initially thought about an Atlas but that tacks on 2k to the price of the build.
Also, I briefly thought about buying a rolled or wrecked late model Rubicon and swapping the 4.0L, and drivetrain, axles etc, and having Throttle Down Kustoms build me a custom Scrambler frame with TJ mounts for the suspension coils and axles, motor and trans.
Does anyone have any experience with the reproduction steel bodies? I know the ones for the MB and 2A are pretty accurate now and with the exception of the angle of the E-brake handle and the lines on the top of the rear wheel houses, are pretty hard to tell from factory....I wonder if the CJ-8's are as accurate?
Way ahead of ya... and I'll probably finish way behind ya. I'm in the middle of what you're describing. I've had lots of Jeeps. I got tired of rust. I started from scratch.
I started with a refurbished (stripped, boxed and painted) 1981 CJ8 frame. Everything else - body, custom dash, motor, interior, cage/sliders, bumpers, axles, 4.5" R.E., wheels, tires... is new. The entire body is from Omix-Ada. Everything lined up, it's straight (as straight as Jeep ever made'em anyway).
The body was painted upside down, then right side up, cage done separately... Then all reassembled...
The SBC is "new" (rebuilt with all new internals) to 1994 2500 Series truck specs. Dana 300, SM465 - would've preferred an NV4500 but a deal fell in my lap.
The interior is the BesTop TrailMax II - the cloth stuff with movable headrests...
So, in the end - it'll be a new Jeep... and probably cost 4 times the original price.
I think, if I could rewind the clock, I'd search the country - patiently - and buy a pristine Scrambler for $10-12k, throw on an R.E. 4.5" list, a full cage and DRIVE IT!
heres what I'm doing right now.. sorta similar.
-Bought a rust free Scrambler, basically for the tub.
-TDK frame with outboarded front spring mounts for my HPD60s, galvanized it so it will never rust
-striped my CJ-7 of the drivetrain (4.2/4.0L with MPFI, T-18, D300, HPD60s front and rear, 2.5" RE military wrap springs)
-swapping Scrambler drivetrain into my CJ-7, once completed, sell CJ-7
-sell rust free CJ-8 frame once everything is taken off of it (probably tomorrow, $1200obo ;))
-swap everything from CJ-7 to TDK frame
-put tub on TDK frame
-painless wiring harness.
-all the little things...
-enjoy.
I really suggest you get a Scrambler to use for parts. or even get a runner with a good body. from what i've heard, aftermarket bodys are not as good as the originals.
Just remember, its the little things that take forever and its the little things that cost the most.
good luck! have fun!! and start a build thread... I know i still have too..
This is SOLID advice Bad Karma. I've done it both ways - with and without a donor. The hard part is not knowing what's missing. When assembling a car or truck - even one as simple as a CJ - there are countless little parts, brackets, etc. that you'd never realize you needed. And if you did, what to call them when looking for them. Well after painting my CJ8, I saw this (the black part) in the bed of a stock Scrambler. I had no idea I was missing these. Can you imagine - how frustrating it would've been when I went to mount the limiting cable - "Where the *#$& does this attach?!"
I think for the money you are willing to spend you will find one that is done darn close to what you are going to build. I also believe you will buy it for much less than you will spend to build it and be driving it as soon as you buy it. Unless you enjoy keeping busy building the exact rig you want and have plenty of spare time to devote to the project than build it. Good Luck!
Manhattan....that is awesome....I can't believe there are that many of you doing this!!! I thought I would log on and have a bunch of "Your an idiot" responses!!!
One reason I wanted to go this route was that I could have a simple, non-emission tested, vehicle, with a V-8 and removeable top.
I thought about buying one finished....but I worry about the strength of stock frames, and of course hidden rust. Plus, I am one of those guys who likes to do it my way.....and I like the pride of building it myself.
The Stretched Wrangler is out of my league....I am not confident enough in my skills to cut a vehicle in half, body and frame, and then weld it together and have it come our right. I can weld a patch panel in....but that is about as difficult a job as I would want to tackle.
Thanks for all the info guys....and I will certainly start a build thread if I decide to go this route!!
I'm with you on this one.....
I think that you need to work some numbers in a a different way.
Rather than 1) starting from scratch with/without a "donor" rig or 2) buying one complete there's a third option.
Spend money to get a nicely rebuilt one for ~15-$20k (that buys A LOT of Scrambler right now if you're willing to search/ship/travel) and spend the rest on the important things you want and tear it apart and redo how you want.
The key would be finding one with enough of what you want to minimize the additional things you have to buy. I think the most important is your comment about the TJ/LJ suspension. This wouldn't be critical though because of the ability to swap your frame in and sell off the drivetrain/suspension that you don't use (see the advantage listed below about reselling parts)
I can think of some distinct advantages to this approach:
-The "donor" will be clean and recently reassembled/rebuilt which minimizes the disassembly/reassembly effort, cleaning, painting (all the little bits are what would kill you) and complete
-Going through disassembly will help with knowing how to reassemble properly
-You can sell off the things you replace and they're going to be in great shape to bring top $$$
-You let someone else take the hit on the devaluation after buying all the parts like you're talking about (this is huge in my mind and the single biggest issue with trying to build one from scratch, projects like this sell for a fraction of the part/labor cost ALL the time)
-You still get to do it like you want it, maybe with some compromises to use donor parts initially that will be replaced later when more $$ is available if it doesn't fit in initial budget.
I used to fantasize about building one completely from scratch, but I've seen a number of really nice ones for very reasonable prices that could be made into AMAZING rigs for the kind of money you're looking to spend. This is more my dream now. :thumbsup:
My $.02
I am also doing this... got a beat up Scrambler for all the little parts and scrambler specific stuff, got a Matkins frame, axles from an 86 CJ and some 81 15x8 Laredos for the rims... tires will be 35's... I have it all in my head, the only thing that will be somewhat difficult is a CJ8 body up here in New England.
Craig
