401... Should I or shouldn't I????
Going Postal
Corvallis
OR
Just came across across a deal in which I will get 2 30 over blocks, 2 sets of rods and 1 crank 20 main and 10 rods. Also get a set of 74 heads with full post mounted valve train. I had just picked up a fully dressed 74K 77 360 and also have a 304 short block and some heads.
Who's running a 401 out there? Anyone in the NW looking for one? I might be intrested in a swap for a good crank that doesn't need turned.
My Scram will be running a postal type top but I was planning on keeping the stock axles and adding one piece shafts. There sporting 3:31 gears. Wont be off road with this and will probubly run 2" lift and 31" tires.
Should I go with the 401 or just drop in the 360 I have?
If your AMC, its 401 all the way!!!
I looked for a 401 for a year, couldin't find one, so built a 360 for my CJ5. The week we were putting the 360, I found a 401. 360 is still in and 401 has been on the engine stand for 5 years now.
Yes
Once you go w/a 401 you'll never go back! In my opinion, if you can get your hands on one for a reasonable amount of money, go for it over the 360. (although the 360 is a great motor too!)
Pros:
Same architecture as all the later model AMC V8's that the CJ series ran.
There is really not a loss in fuel economy over the 360 (except if you use the extra power all the time...)
Many of the same after market parts fit all later model AMC V8's
MORE TORQUE
MORE TORQUE
MORE TORQUE
You can say you have a 401.
Cons:
The only other option I would consider is the 4.0L FI swap. The 4.0L is a great balance of power/torque, fuel efficiency, dependability, etc. and would make a great daily driver. I almost wish I would have gone this way...but I had a couple of 401's and a 390 laying around...and I love the torque.
The biggest negative that I've seen with 401s is overheating issues. It can be hard to get that heat under control.
You got a 390 just "laying around"??? :bow::drool::bow::drool::bow:
Bought it for $25....its "in a basket", everything was there for the most part, but the crank. Funny story, but I came across a 390 crank about a year earlier for $75. Was supposed to be a 401 crank, but when I took it to the machine shop the stroke measured otherwise. In a weird turn of events, I told them to double check that it was a 401 crank before they ground it (unfortunately, the forged P/N was unreadable), they didn't and I ended up w/a ground/polished 390 crank. Due to their mistake they offered to grind my next crank for free, So long story short, I picked up a rebuildable 390 for $100 and got the crank ground for free.
In response to John N's comment about overheating 401's. I've heard this is an issue when blocks have been bored over to the high end (.060") I have run .030" and .040" over 401's w/o any real issues. A good 3 core OEM radiator is sufficient under most conditions. I currently run an aluminum radiator (because it doesn't leak) and a flow kooler water pump on a .030" over, 9.5 ish to 1 CR 401 with no issues at all on the street & typical trail riding. I have had it warm up a little snow wheeling under pretty extreme conditons. (High rpm for extended periods of breaking trail in deep powder where HP trumps trying to stay on top of snow.) Days like those, seems like everyone is, so we just take turns breaking trail.
A great source for AMC V8 info is BullTear.com
Do it and take lots of pictures for us.
At a minimum, if they're not asking a fortune buy it to resell if nothing else. :evil:
Scott, I need to be getting over your way and check out all your other goodies at the shop. Leaves are starting to turn too. Would be nice to get a couple sweet scramblers and the families together for a color tour and some lunch or dinner when they start peaking. Oh, and a few chilly ones, make the wives drive us home... jason
