Scrambler on a budget
Thanks, mine must be a YJ conversion- it comes in from the passenger side too.
today i installed the wiper motor straightened out the linkage and found out i need those cheap wiper refills. however advance doesnt sell those anymore. too old :banghead: i'll look more next week.
next put in the dash pad, and tested everything again. all good to go.
i finished my $20 krylon paint job on the top, so my son and i tossed it on. we think it came out decent.
BUT the top has small swirls over the whole thing about 1/8" - 1/4" long (not from the DA sander), i think it will need some kind of sealer to fix it. i would have to have put bondo on the whole top, and still it may have cracked later. so in a few years i'll find out how to do a better job.
next to do is find a metal valve cover , hook up electric fans steering box brace and find some diff. armor.
if anyone has any of this stuff PM me
tkx
slow weekend, only started on the electric fan wiring and removed the rusty kc lights.
the junk yard cut the harness after i said not too, "some peoples children" so i opened them up and re-wired them. i used a 40 amp VW relay i had lying around, works great. i'll get another one so i can relay both low and high speeds.
i have to go back and get more stuff at the yard so i can finish the job next week .
random pix
i put on my old jacobs omni pak from 10+ years ago. reminder; never throw out anything good :cheers: or it will cost you double :smokin:
huge difference in starting, driving, idling, etc.
i bought a MC2100 today as well. hope to get it next week.
went wheeling with the kids, 1st time with this jeep. no problems went great.
winch works good :D
time to hook up the fans.
i decided NOT to use a variable temp controller or any automatic control at this time. this summer i can easily put in series a temp controlled switch on the low speed relay.
i wired the fans via a on-off-on switch.
this means both fans operate low-off-high
i used:
(2) 40 amp relays, a 40 amp circuit breaker, DPDT switch, random metal strip and lots of connectors. i had most of this stuff lying around. fyi VW's are a great source for relays.
this hole was just beggin for the switch :woot:
next is getting this pig of a valve cover replaced with an aluminum cover
this cant get here soon enough
went wheeling last night to try out the mods. every thing worked great except the valve cover puked out 1/2 qt of oil. However now new problem the alternator doesnt put out enough voltage/current. anyone got one ????????
someone forgot to install his front driveshaft
CANT DRIVE IT MIGHT AS WELL DO SOME BODYWORK, RIGHT?
diamond plate must go i hate the way it looks, i knew i was in for it before i bought it.
so far so good on the back and pass side were in great shape
the drivers side different story :banghead::banghead:
any body men out there want to give an opinion on how to get it done right???????????
I'm no body man but the best way to get rid of rust is cut it out and replace it with new metal.
i got a bunch of parts in over past few days
valve cover, gaskets and grommets. got a good deal from fellow jeeper MKNIGHT759 arrived as promised no surprises
i just hope it doesnt leak :popcorn::popcorn:
i also need an alternator so i figured out how it works. thanks to youtube.
tore it down and it was the original one. it had a lot of corrosion on the stator
the carbon brushes were shot and the bearing was about to seize (it was screaming)
i found a bearing that fit it buried in my tool box :woot::woot:
i took the carbon brushes out of an old central vacuum i had lying around, filed
them down to fit in the holder. soldered them in. i polished the stator and then
re-assembled it. tossed it on and :cheers::cheers::cheers:
this 65 amp unit will have to go at some point to make way for a 100+ amp unit; but for now on a budget this $0 cost repair will work fine.
Nice work! Youtube has been my saviour a few times. I used it to help me with doing a pre-trip inspection to get my CDL. :cheers:
Good work. The high dollar builds are cool but I love to see rig built on a back yard budget
i entered in the cj of the month on jeep forum so if you want to vote for one use this link
http://www.jeepforum.com/forum/f8/cj-month-december-2010-vote-now-1131013/
i hope you like mine best :woot::woot:
my turn signal switch was causing my brake lights to short out and it was all sloppy so i got a new one.
again it was an easy repair. just pull some wire up with the old switch as to help install the new one.
i read that GL-4 is best for "yellow" steel gears. i guess i have it in my t-4 trans and also in my 300 transfer case. i'll keep you posted if i find any difference when i change out the oil.
then its back to the tub and the body work
FYI the GL-4 oil seems better 1-2 and 3-4 shift is much easier. the oil that came out of the trans looked like sour milk :shrug::shrug:
the transfer case oil looked fine on the way out.
Sounds like you might have been able to just pee in the tranny and end up with better shifts :eek: :rotfl:
Sorry, couldn't resist.
You know where the water got in? Is there a breather hose on the tranny? (not sure on manuals)
lol it actually wasnt that bad. i just wanted to change all fluids b4 i drove it a lot.
how strong are the amc 20 rear covers regarding off road use?
Pretty thin metal, but as sturdy as pretty much any stock cover I suppose. I've dented mine pretty well in a couple places and peeled the very edge back, but never something that caused a leak.
good so i'll put the cash to the front then. that dana 30 has a weak cover.
got one for cheap?
the cash saved will go to steering box brace and MC2100 kit and adapter.
then i should be good for a raushe trip with the kids. :evil::evil:
