went out and worked today on the worst section. it never ends this
Q, panel
i cut it as square as possible and now the metal is thick all around
then measured it as best i could. this is always the hard part
this is my metal brake. if i had a real one it would look so much better. but i plan on putting some corner guards on it so it doesnt have to be perfect
it came out better than i thought using the workmate. but the bottom lip will be impossible to do without one. i think i might visit a body / metal shop
no i haven't, i would have to rent one.
i started using a power tool with a scraper attachment on the floor , it seems to work ok
here is the tool pictured
i finished all the holes in my jeep. no more rust holes
now its time to drive it and save up cash for the paint job.
the plan is to remove everything off the tub then drive it to the body shop. they will strip/sand blast all the paint off, prime and paint it. next i'll give them all the other parts to do the same thing. i'll assemble it after i paint the frame engine compartment etc.
i got lucky mine came off in sheets on the sides.
the bed floor was a btich. i used a craftsman vibrating scraper, it helped but the best tool was a thin wood-working chisel
you can see it in the pictures.
