i got a bunch of parts in over past few days
valve cover, gaskets and grommets. got a good deal from fellow jeeper MKNIGHT759 arrived as promised no surprises
i just hope it doesnt leak
i also need an alternator so i figured out how it works. thanks to youtube.
tore it down and it was the original one. it had a lot of corrosion on the stator
the carbon brushes were shot and the bearing was about to seize (it was screaming)
i found a bearing that fit it buried in my tool box
i took the carbon brushes out of an old central vacuum i had lying around, filed
them down to fit in the holder. soldered them in. i polished the stator and then
re-assembled it. tossed it on and
this 65 amp unit will have to go at some point to make way for a 100+ amp unit; but for now on a budget this $0 cost repair will work fine.
