I'm no Mr. Wizard, but back when I went to school, we learned that volume is based on quantity, Density is based on wieght.
So a gallon of water is the same as a gallon of gasoline, even though the weights are different. The Department of Weights and Measures is what certifies this and thats what those embosed stickers on the fuel pumps mean. Hope that clears things up.
For the refill problems your having, its a pickup tube, or vent tube problem.
I suspect those of you that only put 12 gallons in a 15 gallon tank is becouse the pickup tube does not come close enough to the bottom of the tank and your adding to an existing 3 gallons, and/or the vent tube is clogged/kinked and not allowing the 'air' to escape the tank creating an air pocket and kicking off the filler nozzel early. (or some combo of air pocket volume and left over fuel volume on the bottom totaling 3 gallons or so).
For the fuel gauge problem: your fuel gauge reads 1/4 tank empty.....it probably really has 1/4 tank of fuel left, you just cant get to it. Pull the sending unit, I suspect the pickup tube has fallen off or is broken/short. fix that and that should make your fuel indicator more accurate.
If you look at the factory CJ tanks, the bottoms are flat and the filler hose enters the side.
That poses a problem if your trying to suck up every last bit of fuel you have or fill it totally, you cant get the pickup tube low enough, and there is always an air pocket up top. (thus the top vents to bleed the air off)
In more modern tanks, the tanks have a small resivoir in the bottm and a snail like coil that holds fuel in to keep the pickup tube in fuel when the tank is low and you start/stop or go up/down inclines or side to side in turns.
this also alows the tank to empty much more completely. This is especially important on FI engines, the fuel batihing them and running thrue them cools the pump, running them dry can shorten thier life or kill them outright.
Hope that clears things up for everyone
