Gas gauge?????
ds316inya
edison
nj
quick question, when i built my 8, i remember going through alot of trouble calibrating my gas gauge using an ohm meter, and i wrote down ohms at full and empty and have since lost the paper. my question is this. its an 84 with the stock 15gal tank. the other day i ran it low and ran out of gas, the problem is it only took 12.2 gals to fill. any idea why with almost 3 gals left i'm running out? any help would be great, and how easy is a 20 gal tank swap, as far as sending units and fitment. thanks, and sorry if this is in the wrong spot. dave:cheers:
Stock 15 gallon tanks hold about 12 gallons. Stock 20 gallon tanks hold about 15 or so. I don't understand either, but when I figure it out, I'll let you know.
The OEM 20 gallon tanks use a completely different sending unit and check-valve(s), but they bolt in place the same as the 15 gallon tanks. I think the aftermarket 20 gallon tanks use a different sending unit, and brackets that extend the 15 gallon skidplate.
The stock 20 also uses different filler and vent hoses. The filler tube is also longer.
Little known fact: gasoline actually exists in a gaseous state sometimes. That gaseous state displaces the volume of liquid gasoline you can cram into a gas tank. spankrjs schooled me on that one. The more you know...
When I have gas, my wife calls it gaseous and a few other terms as well. :rotfl: :smokin:
man if that is true, that makes a ton of sense. i thought there was three more gallons in there. now is this a jeep thing, because i have a 2010 f-150 with a 36 gallon tank, and when i run that to near dry(notice a pattern here?) its like 36.1 at the pump to refilll, leading me to believe it holds a touch more than 36 gallons. thanks to anyone that can put this to rest for me! and then maybe no more runs till empty!!
True, but you don't have a perfect seal when you're pouring gasoline into an empty or partially empty tank, and even if you did, your vent line to the charcoal canister will accommodate the vapors. Because liquid gasoline is denser than gaseous gasoline, it WILL displace the gasoline vapor in the tank, unless pressure prevented it. With two "leaks" (the lack of a seal at the filler, combined with the vent) built into the system, it will not pressurize while you're filling it.
I got me a si-ence edumakation at a good skool too!
There very well may be three more gallons in there that your fuel pick-up isn't reaching; I honestly don't have any idea how AMC calculated the volumes. I just know that in my '85 CJ-7 with a factory 20 gallon tank, I don't think I've ever put more than 15 gallons in it. (I've only run it completely empty once, in 1993, when I was still in high school, and I don't think I had enough cash to completely fill it.) My other CJ-7, which is the "donor" for my Scrambler project, came with a 15 gallon tank. That one I've run empty and near empty on multiple occasions. I know that if I put in 12 gallons, that means I was running on fumes getting to the station.
For my build, I sourced an OEM 20 gallon tank from a junk yard. I cleaned it, and as it sits in my frame with a brand new sending unit, it is bone dry. I've actually been curious about how much fuel it will hold myself, and I plan to fill it to the brim when I go to initially start the engine.
I did a run-till-you-die test last week that ended with sputtering into a gas station. Took 18.883 gallons to top back up. I don't know if that's truly the max fill capacity or just the last drop the pick tube reaches.
Either way, I've still gotta replace the sender. That sputtering death comes at an apparent 1/4 tank one the gauge. I was NOT happy (nor was I near a gas station) the first time I found that out! :banghead:
OK, then Mr. Wizard, how about this theory: Does the 15g stamp use water as the standard, and is the density of water sufficiently different than gasoline to explain the difference? I have no physics background, but I'd buy it now that we've solved ds's question and there's no risk for thread-jacking. :cheers:
I'm no Mr. Wizard, but back when I went to school, we learned that volume is based on quantity, Density is based on wieght.
So a gallon of water is the same as a gallon of gasoline, even though the weights are different. The Department of Weights and Measures is what certifies this and thats what those embosed stickers on the fuel pumps mean. Hope that clears things up.
For the refill problems your having, its a pickup tube, or vent tube problem.
I suspect those of you that only put 12 gallons in a 15 gallon tank is becouse the pickup tube does not come close enough to the bottom of the tank and your adding to an existing 3 gallons, and/or the vent tube is clogged/kinked and not allowing the 'air' to escape the tank creating an air pocket and kicking off the filler nozzel early. (or some combo of air pocket volume and left over fuel volume on the bottom totaling 3 gallons or so).
For the fuel gauge problem: your fuel gauge reads 1/4 tank empty.....it probably really has 1/4 tank of fuel left, you just cant get to it. Pull the sending unit, I suspect the pickup tube has fallen off or is broken/short. fix that and that should make your fuel indicator more accurate.
If you look at the factory CJ tanks, the bottoms are flat and the filler hose enters the side.
That poses a problem if your trying to suck up every last bit of fuel you have or fill it totally, you cant get the pickup tube low enough, and there is always an air pocket up top. (thus the top vents to bleed the air off)
In more modern tanks, the tanks have a small resivoir in the bottm and a snail like coil that holds fuel in to keep the pickup tube in fuel when the tank is low and you start/stop or go up/down inclines or side to side in turns.
this also alows the tank to empty much more completely. This is especially important on FI engines, the fuel batihing them and running thrue them cools the pump, running them dry can shorten thier life or kill them outright.
Hope that clears things up for everyone
:christmas:
Sort of; gravity is a factor of weight. Mass and density don't change in zero gravity, but weight does.
Back to the earlier question: it's like asking which weighs more: a pound of feathers, or a pound of lead? They are both a pound! Orionn is correct: a gallon of water is exactly the same volume as a gallon of gasoline.
Ice is less dense than water, so it floats. Water vapor is less dense than liquid water, so it floats in the atmosphere above both glaciers and oceans, until something intervenes causing it to liquify (increasing density) and fall.
Liquid gasoline is MORE dense, and therefore "falls" to the bottom of the tank below the vapors. Water is more dense than gasoline, as are rocks, dirt, sludge, and varnish. These could also be taking up volume in a gasoline tank.
My own personal theory is that the volume of the tanks is measured as an abolute volume, but with the air space above the tank based on how the fillers go in, there's no way to completely fill an OEM tank.
kimsanva's run-'till-you-die test is interesting. I've never put that much fuel in my factory 20-gallon tank, but I'm also paranoid about letting it get that low.
When I first bought my current black scrambler I had to drop the tank. It is a factory "15 gallon" tank. I had to clean the tank out since it had dirt inside of it, so I did an experiment. Nothing fancy, just a basic common sense experiment.
1) Took a completely clean/dry 15 gallon tank that was 100% empty.
2) Placed said tank on my flat garage floor, no vent lines, fill lines, or sending unit installed. Just the tank, no more, no less.
3) Used 3 container that I know for a fact each hold exactly 5 gallons. I know this because I have filled said containers up at numerous gas stations. When liquid reaches the "DO NOT FILL PAST THIS LINE" mark, exactly 5 gallons is inside each tank.
4) Filled all 3 containers with water. Poured water from containers into the gas tank through the sending unit hole at the top of the tank. 2 hole containers went in - 10 gallons. Approximately 3/5 of the 3rd container went in before water started pouring out of the vent and fill lines. 10 + (3/5 of a 5 gallon container) = 13 gallons.
My factory "15 gallon" tank will only hold 13 gallons. This is a scientific FACT:cheers: I don't know why they call them "15 gallon" tanks, guess it sounds better then "12.5 - 13 gallon" tanks:shrug:
I have no direct knowledge with the larger fuel tanks:shrug:
I see the same issue on my Scrambler. It typically takes 12.5 gallons to fill if I let it run down past the E. The one time I ran it completely out of gas, it took slightly over 13 gallons to fill it up.
Sorry for my oversimplified explaination. :(
I haven't had to use that type of information in 30+ years......I'm a bit rusty, like my Jeep.
I have a '20gal' tank in my basement, I'll do a volume test this weekend and post the results for you guys.
I do know that CURRENTLY, in the American auto industry, fuel tanks are measured and federally certified with the volume they hold.
that does not mean you will get the same amount in or out. there are other factors that influence the actual volume of a tank.
Like was mentioned earlier, in most new cars and truck, you can usually put more than the specified amount into a tank, becouse of things like the filler hose, you would be suprised at what they can hold.
with the advent of wide spread Fuel injection use, and certain federal standards in the auto industy, fuel tanks have become more than just a steel box to put gasoline in, they have alot of tech built into them now, and it all influences the volume of the tank.
:christmas:
I have to agree with that assessment. Tank rating always seems a bit low nowadays because I tend to fill to pump cutoff. That means tank PLUS filler neck/hose. I could almost always fit ~1 gallon over the rating in a modern vehicle once I knew (by checking) where empty really was. I should say these VOLUNTARY absolute empty tests are done locally while carrying a 1gallon get-me-to-the-pump reserve tank :)
The Scrambler really surprised/concerned me for being less at sucking-air empty. I think (for myself) I'll just set my roundtuit clock to replace my sender sooner rather than later....and fill up at 1/2 tank 'til then!
My gauge reads lower than it is. Mine will read past E and when I fill it, it only takes 10 gallaons. I guess this is better than reading 1/4 but being empty. I am glad to hear that 12 is about what I can fill. That means my gauge is not as "off" as I originally thought.
